DodgeCharger.com Forum
August 10, 2020, 09:02:07 PM *
News: Please remember: this is the place to discuss Chargers - NOT the place to discuss politics. Political posts will be locked or deleted at the Moderator's discretion.
   Home   Help Calendar Login Register Chat
Pages: [1]   Go Down
  Print
Author Topic: Fall Kickoff Sale  (Read 1189 times)
69bfan
Full Member
Offline Offline
WWW
« on: October 15, 2017, 08:56:59 PM »
The 2017 show season was a huge success for us and we only have two more shows for the season.  If anyone should be needing parts and are planning on attending the Garlitis / Ocala, FL. show the second weekend of November, then we will be more than happy to bring the parts to you.  Otherwise, we would like to post some items that we will be featuring through the 2017 year:
1966 Charger 8 Pc. Top Cat Window Felt Kit:  $95.00
1967 Charger 10 Pc. Top Cat Window Felt Kit:  $95.00
1968 to 1970 Charger 8 Pc. Top Cat Window Felt Kit:  $95.00
1971 to 1972 Charger 10 Pc. Top Cat Window Felt Kit:  $150.00
1973 to 1974 Charger 4 Pc. Top Cat Window Felt Kit:  $100.00
1966 to 74 B-Body Door Metro Door Seals:  $65.00 per set
1966 to 1967 Charger Roofrail Seals:  $150.00 per set
1968 to 1972 Charger Roofrail Seals:  $65.00 per set
1968 to 1970 B-Body Door End Plug:  $15.00
66-67 Charger Complete Body Kit, includes body plugs with markings, body bumpers and flaps:  $85.00 per Kit
68-70 Charger Complete Body Kit, includes body plugs with markings, body bumpers and flaps:  $115.00 per Kit
71-72 Charger Complete Body Kit, includes body plugs with markings, body bumpers and flaps:  $150.00 per Kit
68-69 Charger Head Light Vacuum Hose Kit:  $180.00
Daytona, Super Bird Head Light Vacuum Hose Kit:  $180.00
Date Coded Heater Hoses:  $75.00 per set including Corbin Clamps
Date Coded Heater Hoses for AC cars:  $80 per set, including Corbin Clamps
Headliners, starting at $75.00
Sunvisors, starting at $100.00 per pair
Big Block and Small Block OE Correct Negative Battery Cable:  $80.00
Hemi Negative OE Correct Battery Cable:  $80.00
Big Block and Small Block OE Correct Positive Battery Cable:  $145.00
Hemi Positive OE Correct Battery Cable:  $245.00
Hemi and 440 Leaf Spring Rebuild Kits:  $85.00
66 to 70 B-Body Accelerator Pedal, Made in USA:  $45.00
66 B-Body Washer Bottle:  $50.00
67 B-Body Washer Bottle:  $50.00
68 to 70 B-Body Washer Bottle:  $45.00
71 B-Body Washer Bottle, electric or manual:  $55.00
72 B-Body Washer Bottle, electric or manual:  $55.00
73 to 74 B-Body Washer Bottle, pump included:  $125.00
1967 and up Washer Pump:  $27.00
Headliners:  $70.00
Sunvisors:  $100.00
Trunk Mats:  Starting at $45.00 for a rubber mat, not the cheaper vinyl mats that others sell for a similar price.
This is just a short list of what we can provide and our pricing can be even more discounted for larger orders.  Also, check us out for all of your restoration needs from ACC Carpet, AMD Sheet Metal, AMK Fasteners, AMS Obsolete, Dale's Cuda Shop, DMT, ECS, FDC, First Place Auto Parts, Goodmark, Hoffman's Winners Circle, Keystone Automotive, Legendary Auto Interiors, Metro Molded Products, Precision Gaskets, Quirey Quality Design, REM, Right Stuff, Soft Seal, Southwest, Steele Rubber, Stephens Performance and Trim Parts. If there is something in particular that you are needing, just send us a message or call.  We stock most of the products as advertised with the exception of AMD sheet metal, Legendary seat covers and door panels and Right Stuff fuel and brake lines.  Otherwise, product is available to ship and we do not inflate shipping charges.  Most of the items that I will list above are Charger specific, but we stock all of the major body styles, year models and we also now are beginning to stock GM and Ford pieces.
Please inquire for anything that you do not see listed.  We are starting a web site and will be slowly adding product, so it is best to contact us with any needs or questions.
Sincerely,
Richard O'Shields
Restoration Parts and Materials
Ph. 404-643-5760
www.restorationpartsandmaterials.com
r.l.oshields@att.net
Logged
Weatherstripping is our specialty, but we stock a wide assortment of restoration needs.
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.044 seconds with 16 queries.
