Splicing gas lines
Started by NHCharger, November 19, 2017, 12:00:58 PM
NHCharger
I should have looked better at my fuel lines before welding in my new sub frame connectors. I need to replace the front to rear fuel line.  The sub frame connector has a slot in the front where the line goes but I can't snake the line thru two consecutive 90 degree bends.
Is there any problem with cutting the fuel line and using a connection in one spot?
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone- current moneypit
79 Lil Red Express - future moneypit
88 Ramcharger 4x4-moneypit in waiting
2014 RAM 2500HD Diesel
303 Mopar
Of course the best way is to have one solid line.  But if you must splice, I would suggest AN fittings, or even barbed AN fittings.
use a double flare connection
DO NOT USE SLIP ON COMPRESSION FITTINGS
