275s up front
Started by frank1966, January 03, 2018, 09:58:57 AM
frank1966
Any issues with steering? I know I would need to adjust caster camber.
303 Mopar
I had 28x10's (275x60) on the front of my '68.  No issues with traction or steering, but they did hit the frame rail on full turn and would bump the fender on a curb.
frank1966
Depending on ride height and wheel offsets, they will hit the fender brace that is center of outer lip to inner, will catch the lower front corner of fender, and if you change your control arms for lots of caster, they will bump the rear of the fender. Alm can be remidied with massaging depending on your final goal with the car since it sounds like a pro touring style based on your big brake posts and such.
frank1966
thanks, iam trying to fill the fender well as much as possible, just wanted to know if big tires up front will stress the steering components. I am putting 18's with a low profile tire on a wheel that's never been on charger before according to the manufacture. its  modern wheel that starts with a 0 offset. not sure if its going to be a pro touring car, I like modern wheels and modern brakes.
The stock parts will be fine, but check out firmfeel.com as they have nice heavy duty upgrades for the tierods.
Kern Dog
I never hit the fender brace but the tires do rub the frame rail. No biggie, it just leaves a shiny spot.
frank1966
Quote from: c00nhunterjoe on January 06, 2018, 08:17:52 PM
Good thanks
Quote from: Kern Dog on January 06, 2018, 09:52:39 PM
How wide a rim did you use? I had them on 8.5s.
Kern Dog
My fronts are 18x9 with a 4 3/4" back space number.
