Heater Box Restoration
Started by Shakey, May 01, 2006, 08:10:28 AM
birdsandbees
Does anyone know where you can get the moulded rubber blower motor mounting gasket for the '69 B body heat box??? Can't find as much as even a picture of one Googling. Closest I've found is a Ford gasket from Denis Carpenter Ford Restoration Parts
Also anyone on what those stickers would have been??  :shruggy:
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
72Charger72
Not sure if this would help if you cant find the gasket.....just posted by b5blue
For odd ball stuff like that I use "Sugru". It's like putty that hardens to rubber.
https://sugru.com
birdsandbees
Thanks, fixed up what I had so I could complete the box and move onto my dash next.
birdsandbees
Rubbed the metal down with gun oil today. What a visual difference and shouldn't rust again in my life time. Probably should have done the inside as well, but I'm not pulling it back apart!  :rotz:
birdsandbees
Does anyone know what these two "decals" would have been originally on the '69 heater box. Lynch Rd car...
Charger-Bodie
Not factory to my knowledge .
birdsandbees
Cars been in my family it's entire life... nobody put them there. Definitely some mfg stickers / part number or something. I media blasted them off when I restored the box. Just hoping someone has an idea what should be on a '69 box to be correct. My '70 'Bird box has a stamped part number. My '69 Bee never had same, just these stickers.
moparnation74
Never seen those two decals...
Both of my 69's has the PN Stamp....One had the paper "Factory OK" tag on the heat control arm on top of the box(was suppose to be removed on the assembly line)
Beautiful job on the box BTW :2thumbs:
birdsandbees
Thanks, is it the same part number stamp as the '70? The one in my 'Bird is factory stamped still...
moparnation74
They are different......your welcome to borrow my stamp, just cover shipping....
It is 2837500
birdsandbees
Quote from: moparnation74 on October 25, 2016, 02:47:33 PM
It is 2837500
THANKS! very much, I will keep it in mind as I work towards final assembly. Might be cheaper to have the local stationary guy make me one vs the postage from Texas to here and back, but we'll see. Again thanks for the offer!!  :2thumbs:
To edit.. just ordered a stamp online thru staples for $21 Cdn to my door. Will see how close it is to correct when I get it..  :scratchchin:
birdsandbees
What colour paint are you guys using for the stamp? Got my stamp already.. and want to give it a trial run..   :yesnod:
birdsandbees
Guess I'll just color match to the stamp on my '70 Bird box, thought someone would have a color for stamping..
chargedup68
Shakey, thanks for sharing the process!  Going to tackle mine after Christmas.
68 Charger, 608/683 505 cu in. Muscle Motors Stroker, MASS Flo EFI. Reilly Motorsports Alterkation/Street Lynx suspension, Wilwood brakes, Strange Dana 60 4.11 gears, Tremec TKO 600
chargedup68
Took me all weekend, but I got it taken apart cleaned up and put back together.  The 50 year old fiberglass is brittle so my advice after doing this is be gentle!  I tightened down the fasteners just a little bit at a time all the way around the perimeter like I would if I was torquing a head since the new foam fits in snug.  Also, take lots of pictures as you go it will make the reassembly much easier.  I checked the fan motor and it was still good so lubed it up and put it back in.  My heater core was bad, but fortunately I had a spare so it got the fresh one.
66FBCharger
Quote from: birdsandbees on December 30, 2016, 09:23:19 PM
So birds and bees, Can u tell me what you used for the yellow paint for the part number stamp? A brand and part number or description would be a great help. I'm redoing my heater box now and would like to have the paint for when I'm ready to stamp the part number.
Thanks in advance for the info.
'69 Charger R/T 440 4 speed T5, '70 Road Runner 440+6 4 speed, '73 'Cuda 340 4 speed, '66 Charger 383 Auto
SOLD!:'69 Charger R/T S.E. 440 4 speed 3.54 Dana rolling body
birdsandbees
Some can of yellow I had sitting on the shelf in the shop, I'll have to see it I wrote it down in my log.  That said I've since been kicking my ass as I asked many if they'd ever seen a paper sticker like mine had on the cover and everyone said no. I have since learned that this was a QC sticker and the part number may have been printed on the longer label and not stamped. Oh well.. it looks purdy!  :lol:
69bfan
In reading the various post on this subject in regards to the two paper tags, the A12 guys may have some input on the actual contents of what was printed on the tags.  Personally, I do not recall seeing them before.  They could very well be as you state some sort of quality control check.  Very interesting piece of history to be further researched.
Restoration Parts and Materials
Weatherstripping is our specialty, but we stock a wide assortment of restoration needs.
www.restorationpartsandmaterials.com
66FBCharger
Quote from: birdsandbees on January 16, 2019, 06:19:48 PM
Thanks birdsandbees. I want to match the yellow before I strip the paint off. if you could find any info on the yellow you used for the stamp, it would be greatly appreciated.
John
birdsandbees
I'm not going to certify that the colour is OE correct, but I held my test stamp (on black headliner material) up against my super birds heater box stamp and it's damn close, especially allowing 49 years for fade!
Krylon Fusion for plastic. Sunbeam 42330. I sprayed it out of the can onto a piece of cardboard, dipped the stamp and did a few test stamps to get it wet, Then new spray, dip.. stamp box.
rikubot
I know this is a pretty old thread but I thought the answer to my question might add some good information to it.
What kind of rivets do I used to replace the ones I'm going to drill out? I'm fairly certain that they are called "semi-hollow truss rivets" but I am not sure what size and what tool to use and where to get the rivets.
Thanks in advance.
'69 Charger, 440/727
rikubot
I also noticed that the rivets are steel, not aluminum. Do I need to use stainless steel rivets?
Texasdoc
Quote from: 66FBCharger on January 16, 2019, 04:58:59 PM
https://www.hobbylobby.com/Crafts-Hobbies/Stencils-Craft-Paints/Acrylic-Craft-Paints/FolkArt-Acrylic-Paint/p/192
https://www.forbbodiesonly.com/moparforum/members/69chargerr-tse.36841/
Spend the money and do it right the first time, or spend more money and do it over, so it's right.
66FBCharger
Quote from: Texasdoc on February 10, 2022, 08:40:36 PM
Thanks Texasdoc!
