Wiper woes..
Started by 1charger69, February 15, 2018, 05:58:35 PM
1charger69
Ok....here goes........reassembling.....turn the key on....3 speed wiper starts... I have both speeds but it wont turn off in the off position.....the back of my switch does not have an extra tab for the resistance wire....any ideas what my solution could be?  Thx guys
70 sublime
What year ?
Did it ever work before ?
Do you have a 3 spd switch or a 2 spd switch in the car now ?
1charger69
Sorry its a 69... motor works as i bench tested it....not sure on the switch.....can i see a pic of the 2?
Charger-Bodie
If you have a three speed switch it will ha four positions. Off. Low.medium.high.
1charger69
Then its def a 2 speed speed switch....how can i make it work?
BLK 68 R/T
Quote from: 1charger69 on February 15, 2018, 08:15:35 PM
Put a 2 speed motor on it or get a 3 speed wiper switch.
1charger69
So theres no other way around it?
70 sublime
1charger69
Welp...i lubed myself up and bit the bullet and bought one
BLK 68 R/T
Did your 3 speed wiper motor come with the correct crank arm on it? They are different between the 2 and 3 speed. Sounds like your car was originally all setup for the 2 speed, and you installed a 3 speed motor, is that correct?
1charger69
This has been a 20 year rotisserie resto so ive been acquiring parts for years...but i know it did come w a 3 speed wiper setup
