Dixie horn
Started by 1charger69, March 01, 2018, 06:06:34 PM
1charger69
Why cant i hear the trumpets?....the compressor is running and the hoses hooked.....when i installed it last week....it played but it was on the weak side.  Any ideas?  Its a wolo
johnnycharger
Disconnect the hoses and see if it is pumping air out when you are holding the button. Mine was getting weak so I sprayed penetrating oil in it and that helped it.
mopar0166
put 123 oil in the intake for the compressor.  that will help it.  if not your not getting or the compressor seal bad
