window jam
Started by Polygon, March 05, 2018, 12:29:29 PM
Polygon
Just as it sounds, I rolled the window up. Heard a 'small' noise. And now it's STUCK. can't move it a millimeter. So, I am getting the Factory Service Manual out...
I'm sure all the hardware is original.
window is stuck in the 'up' position.
John
PS, it rolled up and down nicely, a while back, I lubed everything. Adjusted nice too. New window felts may have added to the drag.
update, still hard to do, but using Yahoo Advanced search, I found quite a bit here, some going back 12 years.
http://www.dodgecharger.com/forum/index.php/topic,39415.0.html
http://www.dodgecharger.com/forum/index.php/topic,38431.0.html
http://www.dodgecharger.com/forum/index.php?topic=98556.0;all
http://www.dodgecharger.com/forum/index.php/topic,91429.0.html
www.lostinspaceforum.com
If you like the old TV show, Lost In Space, check out my page
Polygon
Looks like I will have to remove the whole vent window and door glass. Reading the posts, I can see this is going to be a bear. and quite frankly, for the first time I feel frustrated. So, according to the FSM,
#1, remove nut from stud on lower end of vent wing. Well, looks like mine was held there with a tie wrap.
#2,remove screw and washer assembly attaching vent wing to belt line. OK, stuck here. Where is this screw and washer?
#3, remove leg wing leg stud from slot in hinge pillar support. I am lost on that one too.
A step at a time here...
F points toward front.
loking under vent window.
and there is this screw on the bottom of the vent window. Do I remove that?
Thanks!!!
70 sublime
Did you try pulling the glass up and down or just turn the crank ?
I think I would try to find where it is stuck before pulling it all out of the door
As you have seen that is not very fun
Polygon
Glass is stuck too. HOWEVER, since the regulator is probably shot, I put vise grips and cranked on it HARD.  Broke it loose, and works good. Down the road, I will replace the regulator. Works ok now.
But will need fixing and replacing in the future.
