Electric headlights
Started by comet_666, April 04, 2018, 08:51:22 AM
comet_666
I have been looking around lately at these. I see the ones from Classic are plastic? Anyone have any experience with either of thee models?
https://www.herbsparts.com/proddetail.asp?prod=CS305
https://www.classicindustries.com/product/mb1723.html
alfaitalia
They are supposed to be slow and wonky and open at different speeds!! You will take all the character out of them if they open "properly" with that new fangled electricity ...!
comet_666
LOL
My problem is I have to manually open them now..I don't have any of the vacuum set up.
Manually opening them is even slower and they definitely do not open at the same time lol
WHITE AND RED 69
They are all plastic now no matter who you order from and are made by Charger Specialties. I ordered a set a a couple years ago and was bummed when the pictures showed aluminum and then the one that showed up was plastic. Talked to the owner of Charger Specialties and he said it costs too much to produce the metal ones so they switched over to plastic a while back
They do work good though. Easy to install and wire up. Just make sure your headlight door is perfectly aligned. My passenger side door slightly rubs so sometimes it needs a little extra time to open.
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
comet_666
damn...oh well, do I need to splice any wiring or are they now pretty much plug and play?
And Thanks WHITE AND RED 69!
WHITE AND RED 69
It is a pretty simple install, only one wire that gets spliced into the harness. Actuators bolt right in, then there is a power module that I installed under the battery tray, one wire to positive battery cable,  one to ground on the negative side, and a activating wire that taps into the high beam switch on the floor.
Honestly the stock vacuum system is bullet proof. All you need is some hoses and a storage can. Easy quick install and my doors open and close very nicely. I'd hate to lose the "psshh" when I hit the light switch.   :icon_smile_big:
comet_666
I would think about the vacuum system but I relocated the battery to the trunk and that canister would look lonely sitting there exposed like that lol.
Ha but look at the opportunity that now presents itself; you could be that guy with the polished stainless steel vacuum can instead of us suckers with the coffee cans.  :lol:
comet_666
I like the way you think Dino! lol
VegasCharger
Quote from: alfaitalia on April 04, 2018, 09:28:22 AM
:iagree: :iagree: :iagree:
Quote from: Dino on April 05, 2018, 07:43:02 AM
Back N Black
Quote from: comet_666 on April 05, 2018, 12:26:07 PM
You can run the lines without the can, the can is to close the doors when there is no vacuum (engine shut off). Just turn off the lights 15 seconds before you shut the engine down, give time to close the doors.
