Got my Charger running
Started by cdr, April 07, 2018, 08:44:19 PM
cdr
Still no tuning I cant deal with the heat , 2nd pass it spun,
Drove 80 miles round-trip,ac blowin cold, overdrive engaged,,11.33@121, full exhaust, just drop the air pressure down to 20 psi and make a pass. DA was 1750 ,4100 lb pig.
cdr
JR
Awesome! I'd be thrilled with those numbers.
And 80mph @2400 rpm.
green69rt
RECHRGD
Looks like you had a heck of a race going there until the end.  What happened to the guy in the next lane?
13.53 @ 105.32
cdr
Quote from: RECHRGD on April 28, 2018, 05:51:45 PM
I dont know, he just let off.
Lennard
Looking good. Cam swap woke it up. Nice 60' for 3.54s
BSB67
11.68 @ 120.2 mph
Nice work Charlie  :2thumbs:
Looks like the cam swap was a step in the right direction  :icon_smile_big:
Using the Moroso Speed calculator :
Old combo produced 117mph@4100 = 510HP
                VS
New combo produced 121mph@4100 = 550hp
Looks like the changes are showing approx. 40hp increase in power.....assuming DA was the same on both days  ;)
I'd be happy with that !  :boogie:
cdr
Thanks Guys !!! :) This is a video that goes with the time slip I posted, I was asleep at the tree left easy & short shifted. :)
https://youtu.be/qusZAXyw9yc
cdr
2nd race, I went up against the converter & blew the tires off.
https://youtu.be/UCgH0_V0dQY
comet_666
