Eddy Performer RPM
Started by Aussi440, April 12, 2018, 09:55:52 AM
Aussi440
I am looking to run the Edelbrock Performer RPM on my 68 Charger with the stock black unsilenced air cleaner.  Has anyone done this?  Any hood clearance issues?
You will have to customize a drop base to use the stock air cleaner, otherwise it wont fit.
Charger_Dart
Quote from: c00nhunterjoe on April 12, 2018, 11:33:28 AM
Agree, that's what I did - I used a Ford MS base and a factory top and don't have any hood clearance issues. I don't think the under-hood insulation would work without rubbing though.
68 Charger R/T & 68 Dart GT Convertible
BSB67
Quote from: Aussi440 on April 12, 2018, 09:55:52 AM
what engine?
11.68 @ 120.2 mph
I think B block won't need drop base like RBs does
XH29N0G
Nacho,  I think you may be correct, but don't completely remember.  I have a 70 B, I ultimately modified that aircleaner to have a slight drop because it still looked very high with the performer RPM.  So the Drop base can also have an asthetic elment to it.  (sort of hiding the fact that it is a higher assembly as a whole.
Or maybe it protects us.
Al
On my 68 Charger with a 383, I had to use a drop base air cleaner for hood clearance.
1968 Dodge Charger, 383, UU1
