Headlight doors
Started by 1charger69, May 03, 2018, 05:40:15 PM
1charger69
The doors go up fine....the left before the right......upon closing.....the left goes down fine ....the right stays up
What are some possible problems/solutions
timmycharger
My car had similar issues, they went up but not down. Ended up being a clogged vacuum hose from when I had everything apart and sitting.  Some compressed air did the trick. Another possibility could be a vacuum leak or incorrectly routed hoses.  Do a search here and you will find a few topics on it with pics from the FSM. Good luck!
1charger69
Ya...im thinking since the left comes down strong.....the problems somewhere between the T and the pod.....cant hurt to put a 3 n1 oil on the pivot points
