69 Tail Emblem
Started by Paul 500, May 14, 2018, 04:19:28 PM
Paul 500
Has anyone got a pic ( & measurements) of where the holes go for the tail emblem non R/T on a 69
68 Charger R/T
69 Charger 500
richRTSE
With the trunk lock removed, it's 2-1/8"from bottom of lock hole to the top of the "g", and the emblem is centered with about 1" on each side...
richRTSE
To actually mark the holes, I would take a piece of stiff paper and push the pins of the emblem through the paper then trace and cut the paper in the shape of the emblem.  Then put the paper on the panel, position it correctly, and mark the holes....there are 4 holes for the emblem and they aren't in a straight line, so probably easier to mark where you need them.
Bronzedodge
I've been looking for a reproduction of that emblem, but I must be missing something, can't seem to find it.  Anyone know who has them?
Mopar forever!
green69rt
Look around on this page.  Don't have any info on quality.
http://www.mrmoparts.net/tail-panel/
I had a repro emblem and had to send it back. The pins on the back didn't line up so the emblem was crooked.
richRTSE
Quote from: Bronzedodge on May 20, 2018, 07:06:33 AM
https://www.yearone.com/Product/chrysler-b-body/vc101#prettyPhoto
Pretty sure this is it. Haven't actually bought one though....
Paul 500
Excellent Thanks richRTSE. Also got a repo tail emblem from Year One & it has 3 studs.
68 Charger R/T
69 Charger 500
richRTSE
The original has 2 pins on the arrow part of the emblem...be careful when tightening it that when the nut starts to cut into the pin you don't twist the arrow and break the emblem...the extra pin would help keep it from wanting to spin.
richRTSE
So I got to wondering about the 3 vs 4 pin thing so I just went out to the garage to look at what I have....the original tailpanel from my Sept 68 built 500 is the picture with the 4 holes, emblem was missing when I got the car...the other picture is another 69 tailpanel which still had the emblem. I just removed it and it only has 3 pins and holes....and that emblem doesn't quite line up with the 4 holes in the other tailpanel.....
Paul 500
That's interesting about the pins
68 Charger R/T
69 Charger 500
