WIW spare tire
Started by F8-4life, May 17, 2018, 07:08:00 PM
F8-4life
Just paid $100 for a original correct spare tire setup.
1968 or 69 date coded Mopar 14" steelie, with a nice goodyear "power cushion" tire.
Apparently this is the correct setup for my 68 coronet..
What is something like this worth?
6bblgt
sounds like $100  :shruggy:
got pics?  what size?  what's the DOT code?
Aero426
Quote from: 6bblgt on May 18, 2018, 12:12:11 AM
:iagree:  The devil is in the details.
F8-4life
hemigeno
7.35 x 14 was pretty much the smallest tire on a 1969 B-body, used for /6 equipped cars only.  I'm not sure about 1968.
What stampings are on the wheel itself around the valve stem?
F8-4life
Tire is in pretty good condition. Still has a stamp on the sidewall.
Rim is marked M38 4 (valve stem) 3 50.
hemigeno
Quote from: F8-4life on May 23, 2018, 12:31:34 PM
... which makes it a product of the Motor Wheel company, Plant #3, made on April 3rd, 1968.  That's likely too early for a 1969 model year car, but right in line for a late-built 1968.
I can't speak for 1968 -- but for the '69 model year, 14" x 5.0" J wheels were standard equipment on Dodge & Plymouth B-bodies other than Chargers, when equipped with 7.35 or 7.75 x 14" tires (Sales Code T2_ or T3_).  For whatever reason, Chargers were supposedly given nothing smaller than 14" x 5.5" JK wheels rather than 5.0" J wheels -- even though their tire size might have been exactly the same.  14" x 5.0" wheels were the baseline, standard equipment on B-bodies equipped with /6, 318, 383-2, and 383-4 engines.  7.35 x 14" tires were the baseline, standard equipment on only /6 Dodge & Plymouth B-bodies, and on 318 Plymouth B-bodies.
For a bit, I was wondering whether it could have been an A-body wheel since you didn't mention the bolt spacing, but those used either a 4.5" or 5.5" wheel (in '69 anyway)... so a 5.0" wheel indicates B-body, large bolt pattern.
That's a longwinded-way of saying had that tire & wheel been in the 1969 model year range, it would have come on a slant-6 Dodge Coronet-series model, or a slant-6 or 318 Plymouth Belvedere-series model.  1968 is probably similar, but I wouldn't swear to it.
:cheers:
odcics2
Nice to have a vast pool of knowledge on this board...
:2thumbs:
6bblgt
got a pic of the DOT code? it doesn't appear to be on the front, look on the back
BDF
Quote from: odcics2 on May 25, 2018, 01:29:27 PM
:2thumbs:
:iagree:
F8-4life
Thanks for the info!
DOT code on the tire is 219014-23
6bblgt
that's not it, DOT code will look like this
F8-4life
6bblgt
T = 1968
S = April
02 = LA Goodyear plant
I think disc brakes required the 5.5" wheels,
odds are: April '68 built 1968 Coronet/Belvedere w/225 or 318 from LA plant w/disc brakes
I'm going to have to check my spare. I think it's the original.
Kern Dog
You guys actually carry a spare tire?   :rofl:
GMP440
Hemigeno:
"That's a longwinded-way of saying had that tire & wheel been in the 1969 model year range, it would have come on a slant-6 Dodge Coronet-series model, or a slant-6 or 318 Plymouth Belvedere-series model.  1968 is probably similar, but I wouldn't swear to it."
For 68' , standard tire and wheels for 318 Dodge b bodies was the 7.35-14 on a 5" wheel.  Mine came that way.  SPD 6/26/68, St. Louis plant.
hemigeno
Quote from: GMP440 on July 14, 2018, 11:57:44 PM
Hemigeno:
:cheers:
Is yours a Charger?
GMP440
    "Is yours a Charger? "  No, I have a 68 Coronet with 318.
