wheel studs
Started by Moeggenpar, May 23, 2018, 04:55:39 PM
Moeggenpar
Anyone know where to find correct wheel studs for a 68'? I bought a set of rear studs ( changing to right hand thread) from Mancini. The pic and dimensions were identical to my original one on their website. I received what appears to be an off the shelf Dorman piece which is nowhere even close. Thanks for any help
got mine years ago from local auto parts store.....was either Schucks or NAPA
This is the one that's supposed to be correct for Mopar rear axles:
https://www.dormanproducts.com/p-2556-610-103.aspx
Moeggenpar
Thanks for the reply, that's the one I need. They sent the wrong stud
green69rt
Quote from: Moeggenpar on May 23, 2018, 07:26:03 PM
Got ,mine from O'Reilly auto parts.  Just about any parts store can get Dorman stuff as long as you can come up with the right part #.
70sixpkrt
 :punkrocka: I need to save that part# for future reference.
Moeggenpar
Quote from: green69rt on May 24, 2018, 05:39:15 PM
Does the one from O'Reilly look like the one on the right which is my original rear one? I've had two different vendors send me the one one the left with that same part # :flame:  Thanks
green69rt
That looks correct.  Part # 610-103.  Take a right hand nut from you car and see if it works.  :shruggy:
I changed out my left hand studs to right hand just to reduce confusion at the tire shop. Getting the new studs in was fun!!
Moeggenpar
Quote from: green69rt on May 27, 2018, 07:36:46 PM
the one I received #610-103 looks nothing like the in John Kunkel’s post above under the same part #   :shruggy: My original is identical to that one. How did you get the stud in?  Thanks
green69rt
Quote from: Moeggenpar on May 28, 2018, 09:41:25 AM
Didn't answer your question.  The ones I got from O'Reillys looks like the new one you show (on the left.)   The ribbed area didn't go all the way to the head.  Works fine.
I started the stud and then used a ordinary lug nut to pull it into place.  As the lug pulled in I added big flat washers behind the nut to get the lug completely seated.   Just be careful that you use a good nut and that you fully engage all the treads on the nut or you may end up distorting the threads on the lug.
Moeggenpar
Quote from: green69rt on May 28, 2018, 11:32:47 AM
Ok thanks, I’ve give that a try. I didn’t the new one would work at all
ODZKing
NAPA had mine for the 67 and 73
Regardless of the installation method, be sure to recheck the torque a couple of times after a few miles because the stud tends to seat deeper in use.
green69rt
Quote from: John_Kunkel on May 29, 2018, 02:54:23 PM
YES!
