Emergency flasher switch
Started by phantom, May 29, 2018, 11:54:48 PM
phantom
 About that, the turnsignal works with the key off. Should only work when key is on, right? There must be something wrong with the harness. Seems like the power for the hazard flasher is connected to the turnsignal flasher, and vice versa. The sockets for both flashers are pre-connected from Painless, all i had to do was sticking the flashers in place. I dont have the blinkers on the hood installed,  would those two bulbs make a difference?
I have to investigate some more  :scratchchin:
Hood bulbs, same as cluster bulbs won't make a huge diff. The load they suck is minimal, 1.5 to 2 watts each. Rest are 21 watts each.
Turnings gets power from acc source, hazzards from batt/alt system
phantom
Found the problem. I put 12v directly to the purple cable that goes to the hazard flasher and pressed the button and voilá: ny hazards work.
