Timing ?
Started by metcoll, May 30, 2018, 05:27:37 PM
metcoll
440 with six pack pistons rpm heads that flow around 300@600, lunati hydraulic 240/250@050 520/547 rpm intake 850 carb..where would you guys put timing at..heads were not milled, what approx compression ratio would I have(closed chamber heads
What heads, what head gasket, what part number pistons.
metcoll
2355 pistons, rpm 84cc closed chamber heads  & 039 gasket
Depending how far the pistons are below deck.....that combo would yield between 10:1 and 10.5:1 and should run fine on pump gas.  :yesnod:
With that cam I'd be setting the base timing at 24-25* BTDC and limiting the mechanical advance to 10* for a total of 34-35* with a fairly quick curve....all-in by 2400-2500 max.  ;)
myk
Every engine is different, so you have to time it by ear as well as trial and error before you find the right setting.  There is no generalized number...
Kern Dog
I ran a similar combo and calculated my CR at 9.7 to 1. This was in 2004.
