Holley Sniper EFI
Started by 303 Mopar, June 09, 2018, 02:42:33 PM
303 Mopar
The 505 stroker in the Charger has been battling vapor lock at times over the past year or so, and I've been watching and researching all of the EFI offerings.  I considered port injection but could not find a set up that would clear the hood since it slopes down toward the front.  I finally pulled the trigger on the Holley Sniper EFI.
All parts including the Holley tank with in-tank pump, new braided lines with AN fittings, Holley EFI distributor with MSD box to be able to have the system adjust the timing and the Sniper unit with touch screen totaled about $2k. Although I think I could have installed it myself, I had a local speed shop who installs these EFI units all the time and has a dyno do it.  He even did a dyno run with the 850 Proform carb before converting it to get a base line number.
The overall HP and TQ difference was minimal which came in around 441 hp and 530 tq at the wheels.  There was also an 20 degree increase in ambient temp when we ran the EFI to near 100 degrees, plus I'm near 5300' elevation.  Since it is a BB stroker, I'm not concerned about MPH but I'm assuming there is some gain.  However the biggest benefit so far beyond a switch of the key and it fires every time, is the instant response from the throttle.
https://youtu.be/R2F_d9_NoZY
justcruisin
Nice, always pleasing after laying down the cash to get a great result. I'm a carb man myself but I can't argue about the benefits an EFI can deliver, good vid too, I was waiting for the smoke scene but.
Any fuel smell with the Sniper system? That's my main issue with carbs. Also, any mechanical noise from under the hood?
Quote from: Dino on June 10, 2018, 09:30:06 AM
You will always have an exhaust smell unless you put cats on it regardless of the fuel delivery type.
Quote from: c00nhunterjoe on June 11, 2018, 06:11:08 AM
True, but it's the fuel smell coming from under the hood that gets me.
There shouldnt be any raw fuel odor under the hood.  :scratchchin:
green69rt
Quote from: 303 Mopar on June 09, 2018, 02:42:33 PM
Did the tank come with a new sender?
cdr
Quote from: green69rt on June 11, 2018, 11:12:22 AM
they are different than the stock sender.
you have to order it.
cdr
303 Mopar
Quote from: Dino on June 11, 2018, 08:06:12 AM
No fuel smell at all.
303 Mopar
Quote from: cdr on June 11, 2018, 11:22:09 AM
Correct, I ordered the new tank with in-tank pump and new sending unit already installed.
Quote from: 303 Mopar on June 12, 2018, 11:36:26 PM
Your exhaust has no odor? Thats incredible. Even modern manufactures with direct injection still need cats to eliminate combustion by products.
Derwud
My car use to dump 1200 PPM's of HC at idle.. I would assume a lower number would smell much less like gas!!!  :drool5:
1970 Dodge Charger R/T.. Owned since 1981
Sounds like a tuning issue. If it wreaks from the tailpipe, something is not setup properly
303 Mopar
Quote from: c00nhunterjoe on June 13, 2018, 07:06:50 PM
His comment was "fuel smell coming from under the hood". There is no fuel smell under my hood at all.
My mistake. I thought you were referring to the exhaust odor as well. Still, carb or injected, there should not be raw fuel odors.
Brass
Quote from: 303 Mopar on June 14, 2018, 09:13:25 AM
Was there any before switching to EFI?  I think what people want to know is whether normal for EFI is less than what is normal for a properly tuned 4 barrel carb.
For me, switching to a dual flow PCV valve reduced under-hood fumes significantly.  I wonder how much, if any, improvement switching to a throttle body EFI would net.
Interesting again. I run no pcv on 2 of mine. Both only have screens for air cleaners. There is zero fumes under the hood. Unless of course i stick my face down the carb, but that seems silly.
Derwud
Quote from: c00nhunterjoe on June 14, 2018, 07:57:41 AM
100k motor with the Mopar 484 Purple shaft cam.. tuned best it could be and maybe 1000 PPM, 1200 was it's daily average...
303 Mopar
Quote from: Brass on June 14, 2018, 02:13:38 PM
There was a little fuel smell but not any different than the other carbureted cars I have owned or been around.  I would say there was a small improvement since there is zero smell now. I would say if you have a strong fuel smell for whatever reason, an EFI would most likely eliminate it.
Kern Dog
I'd be interested in knowing some of the benefits you see after driving it a bit.   :2thumbs:
303 Mopar
Quote from: Kern Dog on June 14, 2018, 11:33:08 PM
I've driven it a few hundred miles and the biggest benefit by far is throttle response. It has been in the upper 90's here and I've had no issues starting the car, even after it sat for 20-30 min which would've vapor locked before with the carb. The screen allows you to configure from over 180 readouts, so having the tach now that I have not had before is another side benefit.
Glad you are having fun with it.  :2thumbs:
Kern Dog
Quote from: 303 Mopar on June 15, 2018, 09:01:32 AM
Thank you.
Was the throttle a bit soggy before ? Did the carburetor setup leave you with flat spots or lazy response?
TexasStroker
Very nice...hope you will continue to enjoy it!
What valve covers are you running?  It looked like they were finned MP units, but with a 440 carved out as well  :2thumbs:
Founder, Amarillo Area Mopars
www.amarilloareamopars.com
Founder, Lone Star Mopars
www.lonestarmopars.com
Contact me for info!
