New shackles doesnt fit?
Started by Jonas_N, June 25, 2018, 04:16:41 AM
Jonas_N
Got this new (And expensive) shackle kit from Hotchkis:
https://www.hotchkis.net/product/heavy-duty-shackle-kit-dodge-b-e-body-from-hotchkis-sport-suspension/
Now when installing it and tightening the nut, the shackles are very loose, I can wiggle them around with my finger.
Its missing about 2mm before going tight against the bushing.
The shackle on the nut end have a smaller hole that locks against the bolt, so I cannot tighten it any further.
Shouldnt a shackle be tight, what am i missing here?
I dont feel like grinding the bolt or put in extra washers to make new Shackles fit. :-\
HPP
Upper or lower bolt? Lower bolt isn't torqued all the way down yet.
Jonas_N
Quote from: HPP on June 26, 2018, 09:37:24 PM
I just hanged the lower bolt there for reference. :)
The upper bolt is torqued to specs and still I can wiggle the right Shackle piece, its loose.
No answer from Hotchkis either.
Looks like I am going to remove 2mm of material on the locking end of the bolt.
MoParJW
I don't think there should be washers on those bolts?
Edit: sorry misread, bolts are actually too long if I understand correctly
'68 Plymouth Satellite sedan 318
Jonas_N
Yep, bolts too long, if i remove washers there will be even more space to wiggle.
The bolt material is quite soft so I can shave off about 2mm in the mill.
Though new shackles for $100....  :icon_smile_blackeye:
