diagnosing running rich
Started by nvrbdn, August 06, 2018, 04:17:07 PM
nvrbdn
I was heading down the freeway going to the drive in. When we pulled into town the Charger just died. I messed with it for quite some time playing with the carb and finally got it to run if you held the gas pedal to the floor. Then kept throttling till I could adjust the idle to get it to run. Got the Charger home under its own power. One guy following me that afternoon told my buddy that I was really gassing him out. So I decided to rebuild the 650 Holley double pumper. The car fired up and seemed decent, but not perfect. So I decided to change the plugs. When I went to Napa this old dude says I am running too hot of a plug for my set up. (I have a rebuilt 30 over 383 with a cam and headers, petronix flame thrower distributor and coil. The cam is lift 484 duration 284 picture off the box included) He said when you add cam, you run a cooler plug. Now for the life of me I have no clue how I came up with the plugs I was running, but they were NGK. So he gets me the stock plug for the engine which is RJ12YC Champion. after all this, the car just doesn't seem right. Well I ran to the speed shop today and they said that the petronix Dist. probably doesn't like the match with Champion and I should be running an NGK plug. I said that was what was in there before, but I already threw them away. They were fouled anyway. They also said that the float level may be my rich problem. So here is where I am at. I can rebuild an engine, take things apart and put them together blah blah blah..... but that's it. I am not a guy that knows why this and that go together to make things purr. What plug would be best for my set up? Which carb would be right for my set up? I am ready to just go buy a new carb and plugs and get this thing running right. The speed shop thinks 600 Edelbrock for the street is perfect. Holley and Edelbrock people say the 600 is all that motor needs. What do the people that are running these engines say????
70 Dodge Charger 500
70 Duster (Moulin Rouge)
73 Challenger
50 Dodge Pilot House
BLK 68 R/T
So...you were cruising down the freeway with no issues and now all of a sudden it became a carb. issue? I'm confused, but it sounds like something else changed. All cylinders firing and getting good spark?
nvrbdn
Right, we were cruising about 65 on the freeway. As long as the foot was in the gas. When we came into town there was a red light. As I got out of the gas the car died immediately. I coasted into a car wash. Now, when I got out and looked under the hood I did notice there was a small leak from the front bowl of the double pumper around the gasket. I tightened the 4 bolts and that issue was ended. Just lucky it didn't become a major issue. I attempted to restart the engine with no luck. After several minutes of trying, I sent Steve on to the drive-in and I called my kid to come aid us. I pulled a plug and stuck my finger in the hole and had the wife touch the key to check compression stroke and matched it to the cap to see that I didn't jump time. All seemed to be fine so while I was waiting for the kid to show up I tried again to start the car by holding the pedal to the floor. It fired up, but died as I let off the gas. So I had her turn the key as I worked the throttle and adjusted the idle up high to keep the engine running. At that point the kid showed up and he followed me home so I could get the car back. It ran like crap going slow, But ran half decently while running down the freeway on the way home. After rebuilding the carb it did pretty good while hitting a few car shows locally, but then I changed the plugs since I knew they were the ones that I had in the car when it had the problem. That's where I am at now,   But, the engine was running rich according to the car following me. They were in a convertible and I guess they were not enjoying the ride.
73 Challenger
Hard to say without being there but almost sounds like a needle and seat is stuck.
nvrbdn
Thanks for the feed back. And what about the plugs? Is it that you use a cooler plug when you put a cam in? And the pertronix needs a certain plug? Thanks. I am a plug and play guy. And when components don't like each other, I am lost. :yesnod:
73 Challenger
bee1971
Quote from: c00nhunterjoe on August 06, 2018, 06:13:17 PM
X2
Or a heavy float , or set high
bee1971
Quote from: nvrbdn on August 06, 2018, 06:41:48 PM
Pull the plugs and see what they look like , black = rich / wet = gas washed or fouled and not firing
Compression / cam / fuel will determine a colder or hotter plug
What # NGK where you running prior ?
nvrbdn
That's my problem, I don't remember what the plug was. Not thinking about it, I threw them away. I am in agreement with out of adjustment floats etc.......    The plugs I had pulled out were black. I will pull these and look at them. On these plugs I might only have 100 miles at the very most.
73 Challenger
metallicareload99
What kind of choke do you have, and what was its position during all this ? A stuck needle and seat makes sense, but I would think a carb rebuild would have fixed that. A "sunk" float also makes sense to me, and is easy to check
Odds are you have low compression pistons in your rebuilt 383. The hotter stock plug is fine and would not cause an instant problem after driving anyway
nvrbdn
Quote from: metallicareload99 on August 06, 2018, 11:42:22 PM
Its a manual choke. The choke wasn't connected to a pull off, and I believe it was open. But as you are questioning its position, I can not 100% assure you that it was since I had no control over it. That would surely explain being rich and not wanting to restart etc...... Now, the rebuild didn't happen until after the drive-in incident. I rebuilt the carb in the next couple days. She fired up and sounded much better. Then I decided to swap the plugs. and here I am.
73 Challenger
nvrbdn
Quote from: c00nhunterjoe on August 07, 2018, 07:01:03 AM
  That is my assumption that the pistons are a low compression. I guess I will just go get the NGK plug that is cross referenced to the RJ12YC Champion to make the Pertronix happy, And just watch how they are running. I am going to pull the Champions today and see what they look like.
73 Challenger
The brand of plug will not make or break the ignition system and in your case, 1 heat range will not either. Something else sparked your instant poor running problem.
Dodge Don
Had same thing happen to me. Went to a car show running great. Start it up to go home and running like shit, felt like missing cylinders....surging...smell of unburnt fuel, could see people behind me waving their arms in their cars as I gassed them out. Managed to get it home. Carb float stuck. Had to fix it, pull and replace all plugs that were now black and do oil change as fuel got into the oil pan.
nvrbdn
[/quote]
Yep, I changed the oil and filter, rebuilt the carb and changed the plugs.  Since I rebuilt the carb I have a hesitation on acceleration. So I don't have 100% confidence in my carb building skills and am thinking I will just replace the carb.
73 Challenger
nvrbdn
Quote from: c00nhunterjoe on August 07, 2018, 09:18:16 PM
  That may be the key to it all. I wont say how instant it may have been. The car had only been on short jaunts for shows and cruises that were within 10 to 15 miles from the house. Then on this trip it was freeway driving, then through a town 25 minutes away to grab others, back on the freeway for about a half hour of straight running. Then into town. It could have been an issue that didn't show because all the other trips were a few miles and low speeds. I am glad that you guys with the knowledge have explained certain things to make it easier to break it down.
73 Challenger
A speck of dirt stuck in the needle and seat will show under low/no load moreso then higher rpm and loads.
krops cars
We run a lot of pertronix in the fork lift industry. I do not care for them much. The Spark plugs you run are the same as oem. I have put Holley's on. New and used. They are temperamental. I would say Edelbrock. 600 to small for a big block. I would at least get a 700. I tried 2 new holley's on a car. Ran like crap. Yes I know how to rebuild and set them. Installed a used Edelbrock. Ran awesome. Edelbrock on the street is the only way to go. Just my opinion. Racing I would use a Holley.
nvrbdn
Quote from: krops cars on August 08, 2018, 02:31:31 PM
I am hearing more and more that the Edelbrock for the street, Holley for the strip. Thanks for the input.
73 Challenger
Never had a problem with a holley being tempermental. Its almost always the installer that has a tempermant issue. An edlebrock or a holley doesnt matter. They are both controlled fuel leaks. Tune one tune the other.
nvrbdn
Quote from: c00nhunterjoe on August 08, 2018, 04:11:05 PM
  You have good answers. Straight to the point. And you made me laugh on this one. Thanks. The fun thing about conversations like this is that you will find diehards on both sides. I have had shops and people tell me that Pertronix works better with certain brand plugs. Others say that a plug is a plug. Some like Holley, Some like Edelbrock. Some say a big block needs a larger carb. I was told anything under a 750 is a bad choice.  While others say a 600 is fine.
     The best part of it all is that it comes down to either a needle and seat were dirty or a float was malfunctioning. I am not a professional rebuilder and will replace the carb with a new one and leave the rebuilding to the people that excel at it. I really appreciate everyone taking the time to discuss this issue with me.
73 Challenger
NGK XR5 plugs are what you should run....readily available at any parts store.
https://www.summitracing.com/int/parts/ngk-3332/overview/
The 284/484 cam is very healthy in a 383. It won't make much vacuum at all which makes tuning the fuel curve difficult. A double pumper style carb is the right choice with that engine combination. It's important to dial in the ignition with an overcammed low compression build. That combo is going to want at least 20* base timing and 36-38* total.
Quote from: nvrbdn on August 08, 2018, 10:48:21 PM
Giving the same long drawn out detailed story over and over and over gets old and hard on my thumbs. I dont try to be harsh but sometimes it comes across that way. Dont get me wrong, i like holley more and am a die hard towards that platform. Even an old school 4779 is more easily tuned then an eddy, and when you get into the higher end dominators proforms and quickfuels the adjustability if threefold.
krops cars
I did not say that the 2 Holley's I put on were new. The Edlebrock was 1 year old. Ordered new Edlebrock. I do agree with 750.
bee1971
Quote from: nvrbdn on August 07, 2018, 08:17:55 AM
Did you ever pull the Champions to see what they looked like ?
Black / Rich ?
Gas Fouled ?
