Brake fluid
Started by flyinlow, September 17, 2018, 10:34:51 AM
flyinlow
Does anyone regularly flush there brake fluid?
green69rt
Yes, all my cars get a brake flush.   This is one item I usually let a garage do because they have a pressure can that blows fluid thru the system quick.  Otherwise you have to add, then bleed, add, bleed till you think you are done.  And to do a good bleed, it takes two people if done manually.
As for interval, whatever is recommended or when I see dirty fluid or about 100,000.  Can't remember interval.
I think brake fluid tends to attract water so you need to change it at some interval to keep it working right and to keep corrosion out of the system.
JR
Yes, I do it once a year in my Charger.
Charger RT
440
Brake fluid is hygroscopic so it naturally absorbs water over time.
2 years is usually the recommended interval for replacing fluid.
The only exception is dot 5 which is silicone based.
Bronzedodge
Yes, I do mine every 2 years.  I motice it does feel different, better after I do it.
Mopar forever!
flyinlow
Probably should add this to this winters maintenance list. Its been a few years.
Agree, 2 years and I'm due now. I bought the thing that pumps fluid through the master so it will be easy.
alfaitalia
Every two years...which is the recommended interval on most cars if you don't want to lower the boiling point of the fluid (due to the water getting into it as said above) or have corrosion in your brake system (for the same reason!). My track bikes now run silicone brake brake fluid ( dot 5.1 ) ...never needs changing as it's not hydroscopic, provides far superior lubrication and works at much higher temps than dot 3 or 4. If your are tempted to use it, it's very important that you use dot 5.1 and NOT dot 5. DOT 5 will react unfavourably with any traces 3 and 4 left in the system whereas 5.1 won't.
flyinlow
Quote from: alfaitalia on September 21, 2018, 12:45:44 PM
I thought about Dot 5 (use Valvoline synthetic 3, 4 now) I thought the drawback to Dot 5 was lower lubrication causing increased seal wear. Dot 5.1 fixed this? Guess I need to do some homework.
440
Dot 5 is silicone based and not compatible with other brake fluids.
Dot 5.1 is still glycol based and compatible with all Dot 3 and 4 brake fluid and retains similar specs to Dot 5. Dot 5.1 is still hydroscopic so it absorbs water and still needs replacing every few years.
alfaitalia
Quote from: 440 on September 21, 2018, 11:09:13 PM
Correct....my mistake. That's what posting at work does!!
