EFI rotor phasing
Started by flyinlow, October 04, 2018, 10:40:04 PM
flyinlow
I switched to Fitech timing control. MSD distributor , phasable  rotor. Eye balled the rotor per the instructions. Starts up and runs.
So I bought a spare rotor/cap for my tool kit in the trunk since the Mopar cap won't work anymore. Just to check I drilled a half inch hole next to the #2 terminal. Also painted a white stripe on the rotor contactor. Used a timing light to check the phasing. Close ,but made a slight adjustment to get the sweet spot. At idle the line is slightly off center, but centers up nicely above 2000rpm.
Just for the fun of it I put the regular MSD rotor on. It runs , slightly offset, but nice to know it or any GM point distributor rotor could get you home if you broke the phasable rotor and did not have a spare.
I darkened the garage and you could see the multiple sparks jumping the rotor/cap gap thru the hole at lower speeds very close to each other. This disappeared at high rpm. I knew The MSD box was suppose to do this but to actually see it was interesting.
I put a 1/2 plastic plug in the hole in the cap and think it will be fine for a spare.
cdr
twenty mike mike
Thanks for posting this.  :cheers: It's been on my to-do list for months, and this was a good reminder.
