Drone comparison
Started by Sixtyeight, October 16, 2018, 12:03:54 PM
Sixtyeight
Hi,
I'm in the lucky position two own 2 Chargers, a 68 and a 69. Both with a fresh rebuild 440 engine. One sounds absolutely fantastic and the other one has a drone from hell in it...
This is the difference in set up:
68 = headers / 2.5 RVS pipes / No H-pipe / Flowmasters Delta Flow 40 = sounds fantastic...no drone whatsoever
69 = Original stock HP manifolds / 2.5 standard pipes / H-pipe / Flowmasters Delta Flow 50 = heavy drone in the car...
According to the experts the Flowmaster 50 should have a lesser drone instead of a bigger one, and the biggest difference are the headers or the H pipe, or the combination...
Who knows the cause of this difference in drone sound?
Jeroen.
Charger Registration of the Netherlands / www.charger.nl
1968 R/T Charger
1969 Base Charger
They will all drone at some range. Its a combination of the specific engine build, load, gears, and sweet spot rpm.
Sixtyeight
Quote from: c00nhunterjoe on October 16, 2018, 12:28:35 PM
As said, the 68 has no drone whatsoever...
Jeroen.
1968 R/T Charger
1969 Base Charger
cdr
are the distributors set up the same, timing,vac adv, ? late ign timing can make the exhaust loud & drone.
Sixtyeight
Yes settings about the same...
Jeroen.
1968 R/T Charger
1969 Base Charger
I have never seen any brand 2 chamber muffler that did not have a drone of some kind. As i said, you are just not in the sweet spot in your driving habits. Thats not a bad thing. The reason you only experience in 1 of your cars given identical engines is because you have 2 totally different exhaust systems on the exact same build.
Both engines have the same cam, compression ratio, carb etc?
Usually the H-Pipe will help with resonation but it looks like this is not true in your case?
don duick
one engine may have  a better balance. I had a really bad drone that was caused by a converter that was out of balance or wrong for the motor.
JR
I have no idea, but I can tell you back when I had HP manifolds, 2.5 inch exhaust with H pipe, and 40 series Flowmasters with no resonators, the drone was awful.
I got fed up with them one day and put a stock style muffler back on, and all the drone is gone. I have shorty headers now, and still no drone.
Just hearing the name "Flowmaster" sends me into a nervous twitch, I'll never buy another set of them again.
I know this isn't a helpful post, but it felt good to get that out. :icon_smile_big:
BSB67
I think there are a set of conditions, both car (weight, gear, converter, cam...) and exhaust related that will make the drone condition better, or worse.  However, everything else being equal, I think that manifolds always worse.  If you use a Dynomax 17747 muffler the drone will either disappear, or nearly disappear initially.
11.68 @ 120.2 mph
TommyGun
On my 68 with 440, when it had manifolds it had a bad drone. Couldn't talk at all or hear radio. I changed to headers and now it doesn't drone at all.
bsakal
Quote from: BSB67 on November 05, 2018, 01:12:31 PM
I had a set of the Dynomax 17747 on my 69 Satellite with a built 383 and HP manifolds, droned like crazy. I took them off and put on AP 6493 mufflers (they are their Big Max Turbo mufflers, long case with dented corners like the hemi muffler), and the drone was in a different range. I added a pair of 4 inch round AP mufflers as resonators like the Hemi cars had - drone gone. The Dynomax 17747 also droned on my stock 66 big block Newport.
69 Charger SE - 66 Chrysler Newport 383
Kern Dog
It is the manifolds, man....No matter what people say, they are like trying to empty a pool through a garden hose compared to headers.
Challenger340
Very little to No Drone at all, almost to the point you wouldn't know the Engine is "on" when driving unless you roll the windows up/turn down the radio, very quiet.
'69 R/T SE, factory original Manifolds/H-pipe/Tailpipes, 2 new "correct" style resto mufflers 6 years ago.
Only wimps wear Bowties !
Sixtyeight
Tried the Walkers Sound FX now on the one with the drone.... Drone gone, but just because they really are silent mufflers....
I think I agree with Kern Dog...I believe it´s the manifolds...if you want a louder open chamber muffler, I think you also need the headers.
Jeroen
1968 R/T Charger
1969 Base Charger
