LED Turn Signal Issue
Started by raybork, October 23, 2018, 05:43:19 AM
raybork
I converted all of my external lights to LED minus the headlights. I installed the LED no-load flasher unit. When I use the turn signal switch in either direction with the headlight switch off, the lights that aren't supposed to be flashing are very dimly flashing also. For instance, I turn the turn signal switch to the right and the right turn signals flash as they should, but the left turn signals also very dimly flash. However, with the headlight switch in the parking lights or on position, the turn signals seems to be working properly. Is it possible that the lights that aren't in use are getting some sort of residual voltage from somewhere? If so, how would I correct that?
ODZKing
I found that most of the LED stuff has a polarity, try switching them around. Otherwise it's back to incandescent.
WHITE AND RED 69
Did you change out both flasher units or just one?
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Derwud
Start by making sure you have 2 LED compatible flashers and then start swapping to standard bulbs until the problem is cleared up.. I suspect you have a bad bulb that is back feeding.
1970 Dodge Charger R/T.. Owned since 1981
raybork
Quote from: WHITE AND RED 69 on October 23, 2018, 01:20:38 PM
I have changed both flasher units
raybork
Quote from: Derwud on October 23, 2018, 02:16:55 PM
I do have two LED flashers. I will give the bulb swapping out a try.
cdr
Bad ground at the bulb socket
Probably the ground in the valance housing screws.
keith88
I had them in mine front and back ..took the back ones out had to many issues with then went back to bulbs in the tail light ,never had an issue with the front ones. :Twocents:
1969 Charger  Orange /black top  (1989) 360 engine stock with added xtreme comp cam and a 4 bbl  , 904 trans/shift kit , 8-1/4 rear.. with general lee accents.
