DodgeCharger.com Forum
July 07, 2020, 01:53:13 PM *
News: Please remember: this is the place to discuss Chargers - NOT the place to discuss politics. Political posts will be locked or deleted at the Moderator's discretion.
   Home   Help Calendar Login Register Chat
Pages: [1]   Go Down
  Print
Author Topic: Copper/Nickle tubing  (Read 919 times)
Old Timer
Offline Offline
« on: November 06, 2018, 05:28:08 PM »
  I'm making my 3/8 fuel line out of Copper/Nickle this time. Reading up on it's much more resistant to effects of water corrosion and easier bending swayed me. I'm just wondering if anyone else has experience to share?
Logged
charger1972
Full Member
Offline Offline
« Reply #1 on: November 06, 2018, 05:59:27 PM »
I work in New York state , so we do a lot of brake lines . Copper nickel is all we use . Really easy to work with , does turn a little green eventually . And it cost more , but is worth it , for us anyway .
Logged
Old Timer
Offline Offline
« Reply #2 on: November 06, 2018, 07:48:14 PM »
For fuel line i would use steel braided on a classic. I use the copper nickel for brake lines all the time. Definatly paint them as they will still corrode but are much eassier to work with then traditional steel.
Logged
Mopar Nut
Old Timer
Offline Offline
Mopar Master
« Reply #3 on: November 06, 2018, 07:52:26 PM »
Stainless steel?
Logged
"Dear God, my prayer for 2019 is a fat bank account and a thin body. Please don't mix these up like you did the last four years."
Old Timer
Offline Offline
« Reply #4 on: November 06, 2018, 10:57:44 PM »
Stainless is even harder so tough to bend for DYI. (I am using some stainless fittings) Thanks for the reply s.
Logged
Old Timer
Offline Offline
« Reply #5 on: November 07, 2018, 10:42:34 AM »
The preformed stainless sets are nice. I put one on my truck.
Logged
Old Timer
Offline Offline
« Reply #6 on: November 07, 2018, 11:39:51 AM »
I'm so over paying for reproduction $$$ I avoid it like the plague.  lol
Logged
XH29N0G
Old Timer
Offline Offline
no matter where you go, there you are
« Reply #7 on: November 07, 2018, 01:02:28 PM »
I seem to remember there might be some chemical compatibility issues, but I am not entirely sure and that might have been with certain grades of stainless.  I just looked up one paper on compatibility with ethanol fuels and it looks like copper, mild steel and brass can be corroded faster.  I saw another paper that said something about silver helping, but also that it could dissolve and clog injectors.  Maybe someone who is an engineer would know.  I looked up compatibility of copper nickel and gasoline to start my search.  I am a novice at this but work with tubes for other reasons (high vacuum lines and highly reactive gases).  We often use softer tubing to mock up systems and then once we have that worked out, proceed with tubing that is harder to bend.  I don't think it should be crazy hard to bend standard wall tubing if you have the right bender.  I know it is difficult with >3/8 and stainless.
Please let us know how it works and what you find out.
Logged
Old Timer
Offline Offline
« Reply #8 on: November 07, 2018, 05:10:46 PM »
The lines in question are not copper. They are safe for automotive use.
Logged
71charger_fan
Old Timer
Offline Offline
« Reply #9 on: November 19, 2018, 04:54:19 PM »
I used it to replumb the brake lines in the '55 Plymouth. After trying it, I'd never go back to steel.
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
Page created in 0.045 seconds with 16 queries.
