Parking lens help
Started by rikubot, December 11, 2018, 05:37:16 PM
rikubot
I'm redoing my parking lenses right now and outside of polishing the pitted clear glass is there a way to make the clear plastic portion smoother or look better?
'69 Charger, 440/727
Tims69SE
If your referring to the front turn signal lenses, I just redid mine, I had the same problem.  Mine were original and beat up from 50 years of service.  I used 2000 grit sand paper and wet sanded the lenses, it left them foggy.  With a Dremel, I put on a soft cloth tool, put thin car polish on the lens and with the Dremel on low was able to polish the lenses, they turned out very good.
I have used toothpaste with sucess :)
mr. hemi
Flitz Polish. Follow the included directions for which material you are polishing.
https://www.flitz.com/
You know you are vintage when someone says, "Back in the day", and you can dispute their facts.
