275 front tires?
Started by INTMD8, February 02, 2019, 12:46:17 PM
INTMD8
I thought I might have better luck here than the wheel/tire section as most probably don't want to do this.
I don't have an aero car, just a 69 Charger but my question is, anyone run 275/60/15 on the front with a 15x8 wheel?
Thanks  :cheers:
62 Max
Run them on back but don't think I would run on front. :shruggy:
odcics2
Depends on what you want to cut out that gets in the way.
Here's what a 15 x 9.5 wheel looks like with an even bigger tire on it up front.
RiverRaider
Quote from: INTMD8 on February 02, 2019, 12:46:17 PM
Thanks  :cheers:
Not that big, I run G/60/15 Indy profile bias ply with 8.5" wheel on the front of my 70 Charger very close but no rubbing.  Those would be close to 245 or 255/60/15 metric size but a little
shorter at a little over 26".  Most 275's are at least an inch taller, about 28" or more and I would think may have more side wall deflection.  I never tried a 275, just assumed with how close
I was that was the limit.  Hoosier tires tend to run a little shorter closer to 27.25" still might not be possible even with stiff suspension and increased ride height.
Let us know if you find a combination that works.
My first Charger was a Stock Car.
INTMD8
Great, thanks for the info!  :cheers:
hemi68charger
Thanks  :cheers:
On a street car application, I would venture no.. the largest I have put on any of my Chargers is 255/60/15's......... 275's are fine on the rears....
Houston Mopar Club Connection
Stevetona
Is that the actual Marty Robbins Daytona? Did it survive or is that a clone? No mistaking that paint scheme.  :icon_smile_big:
moparstuart
Quote from: Stevetona on February 10, 2019, 12:14:33 PM
Replica
I'm running Cooper 255/60R 15's on 15"X8" Tourq Thrust with 4.5 backspace on all four corners. When playing around with alignment I inadvertently got wheel rub at full turn. With stock standard-ish alignment specs they clear everywhere but some areas are pretty close.   :o
69bronzeT5
I had old 275/60/15 BFG Radial T/A mounted on 15x7 Slot mags on the front of my '69 for rollers in the garage and they rubbed pretty bad when turning.
aerolith
255 is the biggest up front with any measure of safety.
235's always seem to drive and steer better on a B-BOD! :rofl: :rofl: :rofl:
Never send to know, for whom the bell tolls,
IT TOLLS FOR THEE...
John Donne 1623
NYCMille
I run a 265/40/18 up front with a 4.5" backspace - no rubbing whatsoever.
