push rod help
Started by DanielRobert, February 04, 2019, 06:27:41 PM
DanielRobert
Hi all,
I confess this is my first 440 build after a lifetime of Gm cars.  I have a fresh 440 block with standard rods and a set of 516 heads. The pushrods I got with the block(1975) are solid all the way through. This is new to me. GM hydraulic lifters have oil holes running through them. I have a Lunati hydraulic cam and lifter set. Which push rods should I be using?
1972 Charger
1969 Roadrunner
1974 Trans Am
justcruisin
Big block Mopars oil through the number 4 cam journal which feeds the rocker shaft through a gallery in the heads which in turn feeds oil to the rockers. Push rod oiling can be used but it isn't required with a stockish set up with a FT hyd cam. You may find that the lifters you have don't have provision for push rod oiling anyway.
DanielRobert
that'll work for me ...thank you
1972 Charger
1969 Roadrunner
1974 Trans Am
Quote from: DanielRobert on February 04, 2019, 06:27:41 PM
Sorry to hear that, but there is allways time to get your life straightened!!!
:rofl: :rofl:  :cheers: ;)
DanielRobert
1972 Charger
1969 Roadrunner
1974 Trans Am
