Sniper EFI fuel line
Started by Ryan.C, February 16, 2019, 12:29:30 PM
Ryan.C
I am at the point in my installation where I need to run a fuel line. The "kit" came with 20 FT of rubber EFI hose. I really don't like the idea of running 18 Ft of rubber along the bottom of my car. What are you guys that have already been there done that doing for a fuel line?
There are few problems in life that cannot be solved with C-4.
If the Sniper instructions don't specifically prohibit non-rubber lines, you can use whatever you like.
WHITE AND RED 69
I ran 2 factory 3/8 steel lines in the stock location.  I trimmed off the ends and added AN fittings so I could attach the braided hose from the ends to the tank and throttle body.
The only pain is that I had to enlarge the hole in the torsion bar cross member to fit both lines through. Other than that it kept everything real clean.
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Ryan.C
Quote from: WHITE AND RED 69 on February 16, 2019, 07:11:30 PM
I love that solution  :2thumbs:
Thanks for that pic
flyinlow
PTFE braided ,shielded where appropriate or steel lines.
I tried standard braided ,but you could smell fuel vapors after a while.
Building the fuel delivery system is more work the EFi itself is.
TexasStroker
I would imagine the Sniper kit included a low-buck version of Earl's that is impervious to ethanol based fuel.  If it is straight rubber it is useless with today's gas.  I think my Terminator kit came with Earl's Super Stock hose.
The twin factory lines is a good option, you can bend your own, route the return opposite if it works better with your setup etc.
You'll be surprised how expensive some of the high end hose can be...kind of makes factory re-pops or SS look pretty good, lol.
That said, if the included hose is pressure rated and safe with ethanol blends, hang on to it as you will have a nice backup hose for roadside repairs or replacing flex lines every couple of years...that is exactly what I'll do with mine.
Founder, Amarillo Area Mopars
www.amarilloareamopars.com
Founder, Lone Star Mopars
www.lonestarmopars.com
Contact me for info!
