Fuel Pump
Started by Frank, March 17, 2019, 08:33:37 PM
Frank
I have a 69 RTSE 440 and the fuel pump just doesn't seem to deliver when I really get on it.  Anyone have a brand that works best for them?
Paul G
Check the length of the push rod. It might be worn.
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
justcruisin
Carter M6903. Used it for years on a 10.2:1 Edelbrock RPM headed 440, plenty of fuel delivery.
XH29N0G
I would have given same information as in both above responses.  I had a similar problem.  Pump rod had worn down.  When it was out, I changed to the pump described in the post above.  It is a nice pump.
Or maybe it protects us.
66FBCharger
What should the fuel pump push rod length be?
Who sells a good quality push rod?
Is it still available from the dealer?
'69 Charger R/T 440 4 speed T5, '70 Road Runner 440+6 4 speed, '73 'Cuda 340 4 speed, '66 Charger 383 Auto
SOLD!:'69 Charger R/T S.E. 440 4 speed 3.54 Dana rolling body
XH29N0G
The producer may not matter, but for what its worth, I bought one of the comp cams pushrods and so far have not had a problem.  They list the length as 3.220"  at mancini racing.  (https://www.manciniracing.com/cocafupupu.html) you can get them from a number of places  I would shop around for a good price.
kevs1969daytona
I would make sure you can get it out.  Theres a "hex" screw right underneath on the block (think its a hex maybe wrong but it opens up to let the rod fall out) , mine was seized.  A electrical pump maybe the best.  :Twocents:
