stroker oil pan
Started by hemi o, March 26, 2019, 11:35:25 PM
hemi o
Hey all, I have a 522 stroker,hi volume oil pump,will a hemi oil pan have enough oil capacity for my engine,or do I have to go to a seven quart pan.
thanks.
cdr
Quote from: hemi o on March 26, 2019, 11:35:25 PM
thanks.
Works on my 512.
BSB67
Generally, the high volume pump has nothing to do with it.  Internal clearances, and any other things that you or your builder did to use extra oil elsewhere will dictate how much oil will go topside potentially causing a problem.
Generally it won't be a problem.
11.68 @ 120.2 mph
