leaf spring question
Started by skippychad, March 29, 2019, 03:57:05 PM
skippychad
so I ordered a left and right mopar performance leaf spring for my 69 charger.  the part numbers were off by only the last digit.  after install..of course, I noticed the right side has one extra leaf.  is that normally the case?  thanks in advance
XH29N0G
On the stock suspension, the number of leaves and 1/2 leaves is different on the two sides.  I don't remember the exact count, but can try to look it up if you want.  I don't have access to my FSM at the moment.  that is where I would look.
Or maybe it protects us.
The left/right staggering only showed up on performance setups, though.  Base model springs were even on both sides.
XH29N0G
we learn something every day.  Mine had the heavy duty suspension so that might explain my answer.  Good to know the others were symmetric.
kent
Just finished tearing mine down not more than a hour ago. Four and half on each side.
Kent
BLK 68 R/T
My 68 has the 440/Hemi springs. 6 left and 5 + 2 half leafs on the right.
Mopar Nut
 :popcrn:
