Budget 68 Charger build
Started by 70B5Cuda, May 10, 2019, 11:23:08 PM
Kern Dog
I just remembered. They call the car "Maximus"
70B5Cuda
I love the stance and rear tires on that Charger
1968 Roadrunner-6.1L, 6 speed, 3.91 Getrag, IRS
1968 Charger- 6.1L, TR-6060, 9"
1968 Charger in RR1 "Ribeye"
1969 Charger in EW1 "S'more"
1969 Charger Survivor-R6, 383, 727.....WRECKED
1970 Barracuda-6.1L, 6 speed, 4.10 S60
ACUDANUT
70B5Cuda
70B5Cuda
Right quarter needed some straightening...
Kern Dog
Looks better than mine!
ACUDANUT
Quote from: 70B5Cuda on June 12, 2020, 08:55:52 PM
So how do you "straighten that" Add metal ?
Kern Dog
70B5Cuda
Kern Dog
70B5Cuda
The area under the battery tray was rusty. Used a solid original donor...
70B5Cuda
Quote from: tan top on June 18, 2020, 01:38:11 AM
looks good ! nice work  :yesnod: :2thumbs: :cheers: :popcrn:
Thanks!
A previous owner cut out part of the passenger side wheel tub...apparently for a patch.
70B5Cuda
The left quarter panel patch was AMD and needed trimming since it was too long-see the first picture.
70B5Cuda
Right quarter panel patch...
ACUDANUT
Gas or flex core ? The welds look spotty. Did you weld the entire panel, then grind ?
70B5Cuda
Quote from: ACUDANUT on June 22, 2020, 02:17:29 PM
I'll have to ask the guy that did the welding
70B5Cuda
Rear valance and trunk braces are in...
nchrome
Did you test fit your corners before welding up everything. l didn't and had a tough time installing them and making the seams look rite. :brickwall:
70B5Cuda
Quote from: nchrome on July 01, 2020, 09:31:16 PM
The corners were test fit...they fit terrible. The corners have to be completely cut/bent to make them work right.
The repro valance corners aren't the problem.  It's that so many other large repro panels come together in that area.  The quarters, trunkfloor, extensions, etc . . . the differences all stack up.
A few years ago somebody on this site had pics of fitting a repro quarter panel with the solid original valance & corner cap still in place.  The repro quarter skin was too big in that area.  He shortened the back/bottom end of the lower quarter skin about 1/2" before it fit right.  He basically made a vertical pie-cut (big end of the slice of pie at the bottom) and then welded it back together.
70B5Cuda
Does anyone else remember where that link might be or who posted it? That would be nice to see.
cdr
Quote from: 70B5Cuda on July 05, 2020, 07:05:12 AM
If you bend,twist the rear cross member ends like mine was done from the factory & they fit great with no cutting
mopar4don
Quote from: cdr on July 05, 2020, 10:14:58 AM
Charlie recommended this to me and it works!
ACUDANUT
What is this ?  :shruggy:
