Budget 68 Charger build
Started by 70B5Cuda, May 10, 2019, 11:23:08 PM
ACUDANUT
I admire your work and dedication.  :cheers:
TexasStroker
Coming along nicely!  Thanks for the insights on the needle scaler too.
Founder, Amarillo Area Mopars
www.amarilloareamopars.com
Founder, Lone Star Mopars
www.lonestarmopars.com
Contact me for info!
70 sublime
Save the old floor part that has the holes for the gas tank filler and drain till you have the new trunk floor
I had to make the drain hole in my floor so was handy to have to find the right spot  :2thumbs:
70B5Cuda
Quote from: 70 sublime on August 04, 2019, 05:02:15 AM
Thanks for the heads up!
1968 Roadrunner-6.1L, 6 speed, 3.91 Getrag, IRS
1968 Charger- 6.1L, TR-6060, 9"
1968 Charger in RR1 "Ribeye"
1969 Charger in EW1 "S'more"
1969 Charger Survivor-R6, 383, 727.....WRECKED
1970 Barracuda-6.1L, 6 speed, 4.10 S60
70B5Cuda
I spent about 4 hours grinding spot welds and peeling ip the remaining strips of sheetmetal. It doesn't look too different...
ACUDANUT
 Wow, I thought you said this car was pretty solid ??
70B5Cuda
It really is quite solid....for sitting outside for 25+ years! It's still more solid then most Mopars...especially most north of Interstate 70. It just looks bad because everything is laid open. If you looked in side most frame rails, you'd be shocked. My 70 cuda front frame looked rock solid, but when I decided to do custom full length frame rails, we removed the front frame rails and they were disgusting inside.
70B5Cuda
I spent about three hours knocking undercoating out of the wheel wheels and from the hump above the rear axle. I think I have about 3-4 more hours until it is completely finished.
TexasStroker
70B5Cuda
Finally found the time to remove the every last bit of the undercoating...
ACUDANUT
70B5Cuda
Quote from: ACUDANUT on October 18, 2019, 10:25:54 PM
Why not just sand blast it ?
It will get blasted, but blasting does not remove the undercoating. To get a clean sandblasted product, you need to remove undercoating first
VegasCharger
Quote from: 70B5Cuda on October 19, 2019, 02:33:20 PM
Agreed!! Or it will cost you tons more IF the service elects to try it. More man hours.
I just did a '66 B Body with factory under coating. Not my car, I was paid labor. Thankfully it was on a rotisserie and even still it took awhile.
Good luck with sandblast outcome.   :cheers:
70B5Cuda
I finally got back to this Charger. I sent it out to the media blaster...
ACUDANUT
Keep up the good work and don't forget to show us the after effects.  :cheers:
70B5Cuda
The day after I got it back, it got sealed in epoxy. First three pics are bare metal. Last two are in primer
ACUDANUT
Looks like a winner to me. !!
chargerperson
Looks good.  Thread title may need to change to "medium budget" build as you are doing a great deal of work
70B5Cuda
Quote from: chargerperson on April 26, 2020, 10:40:03 AM
Very true. I have two other Chargers that may take all my resources before I get to this one!
ACUDANUT
I think you and Kern Dog are in a race now to finish their project first.  :cheers:
70B5Cuda
Quote from: ACUDANUT on April 26, 2020, 08:46:22 PM
Im sure he will win this one. I have too much going on.
ACUDANUT
Don't put too many irons in the fire at one time. !!
70B5Cuda
Quote from: ACUDANUT on April 27, 2020, 09:52:52 PM
Too late. lol
chargervert
It seems like you are making real forward progress on all off them too!
darbgnik
Quote from: 70B5Cuda on April 27, 2020, 09:16:03 PM
Im sure he will win this one. I am dragging four other Mopar projects along at the same time...a 70 Barracuda, a 68 Charger, a 68 Roadrunner, and a patina'd 68 Charger.
68 Roadrunner with 6.1L hemi, 6 speed, IRS rear suspension..
https://www.forbbodiesonly.com/moparforum/threads/1968-runner-post-w-6-1l-6-speed-irs.137000/page-8
70 Barracuda with late model hemi, 6 speed, Strange 60......sits LOW
https://www.pro-touring.com/threads/85958-Heavily-modified-1970-Cuda?highlight=
68 Charger with late model hemi, 6 speed, and Ford 9" (don't hate me!)
http://www.dodgecharger.com/forum/index.php/topic,131677.0.html
68 Charger with mostly original paint and cool patina
http://www.dodgecharger.com/forum/index.php/topic,137423.0.html
You are ambitious! And the RR is painted, so you should have it together and on the road in a few weeks, hahaha.
Brad
