cluster voltage limiter
Started by John G, May 14, 2019, 01:02:08 PM
John G
Hey all  there is a prong on the backside of the limiter. Is this supposed to be grounded?  I don;t see it clearly in the wiring diagram.
thanks
doctor4766
Quote from: Dino on May 22, 2019, 09:05:39 PM
Nope, no ground.
I thought the casing was grounded though right?
Gotta love a '69
John G
thanks guys   I thought I read that the cluster was grounded when screwed in but do you know if it's one screw in particular the makes the ground?
Yes the casing grounds onto the circuit board and the instrument cluster screws ground the whole unit to the dash.
John G
Highbanked Hauler
 Is there an advantage to installing a NEW solid state I guess they are voltage limiter ?
92 Cummins Turbo Diesel
04 PT Cruiser
Quote from: Highbanked Hauler on May 31, 2019, 09:19:47 AM
Yep, good added security. RTE IVR4 is what you need.
John G
thanks for the tip
I did get a new one and installed it but gauges still not working -- I'm getting too old to keep sticking my head under the dash!
Quote from: John G on June 01, 2019, 04:42:17 PM
thanks for the tip
Remove the circuit board and solder the pins to the board. That'll fix it. Common issue.
