Disk Brake Booster
Started by chaos52, May 20, 2019, 10:09:55 PM
chaos52
Does anyone have any recommendations for a brake-booster + master cylinder setup for a disk brake setup? (disks in front and drums in back) This is for a '69.
I have no core and would like the Bendix dual-diaphragm type, but don't like the $400 price tag from YearOne.
This thing from MBM is a bit more reasonable at $300: https://www.ebay.com/itm/MBM-1948-71-Dodge-Truck-1962-76-A-B-E-Body-Mopar-Bendix-Dual-Power-Booster/123726012811?fits=Model%3ACharger&epid=10015332641&hash=item1ccea5218b:g:uM8AAOSwV9RcukOp
Anything better available?
Bronzedodge
Find a used one and send it to Booster Dewey for a rebuild.
Mopar forever!
Does the mc have to be stock?
Performance online sells them for 279.
BrianShaughnessy
Quote from: darbgnik on May 20, 2019, 10:52:10 PM
How bout $345?
https://www.ebay.com/itm/1966-70-Charger-8-Dual-Power-Brake-Booster-Master-OE-Bendix-Style/161544920345?fits=Make%3ADodge&hash=item259cd3dd19:g:8BkAAOSwhV1ckQDL
I used this same setup last year.   Works good.    I got it from a different vendor for slightly less but the kit is complete.
Original booster / MC setup I had on Sinnamon that I cobbed together off rockauto would hang...  So I replaced it all at once.
DAY CLONA
How bout $345?
Agreed....This would be a better set up for the OP, as long as he dosen't have a HEMI underhood, will work fine with any A, B, RB, and much better than a single diaphragm booster, as well as being more user friendly with stock components under hood and under dash, just about everything you need is there in a one stop shop as well as good price...
Mike
chaos52
Quote from: c00nhunterjoe on May 21, 2019, 05:53:59 AM
I'm seeing $410??
https://www.performanceonline.com/1962-74-Mopar-Dodge-Chrysler-Plymouth-Car-Power-Chrome-Brake-Booster-Kit/
How bout $345?
Thanks that looks like it would be a good option. Still pricey IMO, but probably better than trying to cobble something together.
Quote from: Bronzedodge on May 21, 2019, 04:52:55 AM
I'm going to call them and see if they'll sell me a core (or maybe I can trade my sh*tty single diaphragm drum booster for a dual/disk. The prices on the website are quite good: http://boosterdeweyexchange.com/
krops cars
I used the Right Stuff brake conversion. I thought they were very reasonable. Good quality. I purchased the chrome unit, but they have  original finish.
Dano 1
If you have power drums now you shouldn't need the firewall plate or pedal linkage so you can get just the boost for $225:
https://www.ebay.com/itm/1966-70-Mopar-OE-Bendix-Style-8-Dual-Power-Brake-Booster-for-Mopar-B-Bodies/171568883582?fits=Year%3A1969%7CModel%3ACharger&hash=item27f24d677e:g:I9AAAOSw04Zcmlh2
Master cylinders can be had pretty cheap from advance/autozone/rightstuff to save a bit of coin over buying a complete set.
1969 Charger 383 2bbl, R4 red, White hat special project
Check out my website for 3D printed restoration parts and accessories.
www.nextgendesignsnc.com
chaos52
Quote from: Dano 1 on May 21, 2019, 10:52:48 AM
Good to know, thanks. So the drum and disk pedal linkages are the same?
I got the whole setup off of a '70 charger with power drums. Now I'm using the pieces for a disk/drum setup on a '69.
chaos52
Quote from: krops cars on May 21, 2019, 10:26:10 AM
Hmm, these don't look correct. There shouldn't be that bracket on the back of the booster. Am I remembering correct that this setup is for drums?
https://www.getdiscbrakes.com/parts/1969-Dodge-Charger/brakes/brake-boosters-and-master-cylinders/brake-boosters/
Quote from: chaos52 on May 21, 2019, 09:45:23 AM
I'm seeing $410??
How bout $345?
You linked a chrome one for 400 bucks. The stock style is 279.
chaos52
I just ordered the Bendix style booster from Pirate Jack and will use an Advance/Autozone master cylinder. Will report back with the results...
https://piratejack.net/1966-1969-b-body-mopar-bendix-style-booster/
What is the master you are getting?
Quote from: DAY CLONA on May 21, 2019, 08:27:48 AM
How bout $345?
Mike
Actually that is a Hemi MC....the hemi master has the lines exiting on the fender side....all others exit on the engine side....
chaos52
Yes that is the correct Cardone rebuilt unit (10-1475)
At one time In 2007 or so) NAPA made their own "brand new" casting (I have one on my Charger)  Even though it said "remanufactured" on the box, the casting was new & far superior to the original in where the MC cover sealed....no leaks from this bad boy
chaos52
Nice, that looks like much better quality. I'll check at Napa before buying. Thanks!
EDIT: oh, what the hell!? Napa carries the booster/mc combo for $155  :brickwall: https://www.napaonline.com/en/p/NBB503603
Dano 1
I've tried to order that combo unit from Napa with no luck, I've called multiple stores and they've all told me it's not available in their system to order. I'm not sure if it's a legacy number or what but I gave up.
chaos52
The booster from Pirate Jack required routing out the holes in the stiffening plate and firewall. Other than that it fit ok.
I got the MC from Auto Value. It was $75 and has the thicker walls like the NAPA unit Just 6T9 CHGR mentioned above.
