Electric water pump
Started by comet_666, June 18, 2019, 07:40:36 PM
comet_666
I was thinking of going with one and adding a puller fan to my setup.
Pro's /cons of a setup like that? Thoughts on what pump/fan set up works well
My car runs around 180-195 but for piece of mind...  or am I wasting my $$ ?
running Wizard 26" radiator 1640-100  / 1.25" tubes
http://www.dodgecharger.com/forum/index.php/topic,124503.0.html
as always, thanks!
In most cases on a primarily street car, the stock pumps are the way to go. If it were more strip oriented then street, i would consider an electric pump. Meziere is the best. Have them on 2 of mine. The charger has a cvr in a stock style aluminum housing. I personally have no issues. The cvr cools my filled block 440 fine with a 22" radiator and 1 large puller fan.  The mezeire gets the job done on the max wedge with a filled block and iron heads and a 22" radiator but at long idle in the summer it will creep up with only 2 small puller fans until i get to about 20 mph. I dont have enough surface area covered with the fan setup but im out of room in that one.
    Conclusion: leave the stock setup alone unless you are crazy like me.
comet_666
LOL
ok..I will take your advice
the reason I ask is because I want to add a puller fan assembly that my fi tech can control and there is no at all there.
thanks!
darbgnik
Quote from: comet_666 on June 19, 2019, 10:29:49 AM
LOL
thanks!
Seems most puller fans will clear the water pump pulley as long as you stick with v-belts, mine does, just. Also controlled by my EFI setup.
Brad
