'68 Charger tail lights
Started by john108, June 19, 2019, 01:06:27 PM
john108
About to install the tail lights.  The 3/16 dia. Studs protrude about 3/4 inch into the trunk.
#10-24 thread I believe.
What does the retaining nuts look like?  Simple nut or something more complex??
cdr
it is a nut with built in washer , call Tom @ R/T specialties he has what you need
john108
Thank You
It appears that I Have a bag full of those formed nut/washers.
cdr
gtx6970
What ive seen on every 68-69 Charger Ive looked at while doing 2 different cars
10-24 machine thread nut, .75 Diameter washer , Yellow zinc di-chromate plated
cdr
Quote from: gtx6970 on June 19, 2019, 05:22:34 PM
Yep thats whats on my car in the picture I posted  :)
john108
Thank you.
That means that the nuts I have are not right.
I will also have to search through all the plastic bags I have in many hiding places.
john108
I found 9 of them.  They look 50 years old.  Have to see if I can clean them some.
