EFI
Started by cdr, June 28, 2019, 04:41:09 PM
cdr
Working on TRYING to get the car ready for the Lone Star Mopar Fest in Baytown HRP, next weekend, I REALLY hope I can make it, bad health SUCKS.
Installed the Holley Dash That I got from Rich [fastman efi],, With the Indy single plane intake it had 4" vacuum in gear @ about 900 rpm, now @ 700,800 rpm it is about 9" with the Individual runner Hilborn EFI.
        https://youtu.be/npyAUoZnDYU
XH29N0G
Nice.  Thanks for posting
Or maybe it protects us.
alfaitalia
Most importantly....have you had it on the rollers to see how many extra ponies you are getting....which is the whole point after all. Assuming you had a dyno reading before the stacks to compare it to of course!
cdr
Quote from: alfaitalia on September 27, 2019, 05:29:46 PM
No dyno for me, track times & MPH , I had bad fuel problems last time out with a Holley HP 950 carb. ran 11.11 4050 lbs,,7.07 1/8
70 sublime
When you stomp on the gas the RPM face turns red
Does that not make it hard to read the red needle on the RPM or does turning red mean something and it goes away after it settles out ??
cdr
Quote from: 70 sublime on September 27, 2019, 09:18:24 PM
I had set the shift light low so I could test it without having to rev the engine to 6500 rpm sitting in the garage. it works :)
TexasStroker
Very cool...Digital Dash has been on my wish list for the Duster.  Hope you get to take the Charger out and have some fun!  A few outfits have made dedicated instrument panels for the Digital Dash...I'm sure anything Chrysler related will be on the back burner, but might eventually come out.  I think I'd still use it as an aux unit for the Charger...factory styled dash is too nice, lol.
Founder, Amarillo Area Mopars
www.amarilloareamopars.com
Founder, Lone Star Mopars
www.lonestarmopars.com
Contact me for info!
chapel40
Don Chapel
cdr
Paul G
Very nice work. The injection looks awesome and sounds great too. I understand health issues, best of luck with that.
Mopars Unlimited of Arizona
http://www.moparsaz.com/#
