Antenna Question:
Started by Captain D, November 04, 2019, 12:12:04 PM
Captain D
Hi folks,
Just curious what antenna mast this may be & where to find one. It appears to be the correct mounting base (as far as it can be seen), but the mast is quite short. Thanks for any insight...
Alaskan_TA
It is broken.
Not many people bother to sell broken antennas.
GMP440
  Simple repair.  Hope you did not throw the rest of antenna away.  Use a pair of pliers and remove the section that is still on the base.  It's just pressed on.
  Then take the good section, smooth the jagged broken part and insert it into the base.  Did that over 20 years ago when I broke mine.  Still stayed together to this day.
