Camber bolts
Started by darbgnik, December 09, 2019, 06:30:33 PM
darbgnik
So I ordered QA1 tubular upper control arms, and figured I may as well use replacement camber bolts while I swap them, but I've found 2 different styles available on Rock Auto.
2.25 degrees of adjustment bolts, and 1.05 degrees. Which is factory, and which should I use, knowing I will gain caster with the new control arms anyway.
thanks
Brad
375instroke
I'm sure they are all the same. You can only move the arm as far as the slot in the car is. The cam can't move it any farther, for more adjustment, and they all look the same. If one actually gave you more than twice the adjustment of another, you'd see a big difference in their appearance.
darbgnik
Quote from: 375instroke on December 09, 2019, 07:54:28 PM
I'm sure they are all the same. You can only move the arm as far as the slot in the car is. The cam can't move it any farther, for more adjustment, and they all look the same. If one actually gave you more than twice the adjustment of another, you'd see it.
Now that I think about it, I'm sure you're right.....
thanks!
Brad
