roof assembly order
Started by 5wndwcpe, February 05, 2020, 07:30:04 PM
5wndwcpe
Before I dig into this (possible) roof replacement, can someone tell me the order of assembly on the roof ?  Was the roof attached to the underlying structure and then the drip rails installed on top of that ?  I've searched a number of posts and can't quite find any pictures that show it clearly.
Or put another way, where do I begin to remove the roof skin in order to do a repair on the skeleton ?  And, of course, reassembly ?
Thanks,
Pete
gtx6970
roof is over top of the drip rails
Under the rear quarter panels though
5wndwcpe
Highbanked Hauler
Quote from: gtx6970 on February 06, 2020, 05:08:58 PM
  The top edge of the quarter goes under the roof or I made a big mistake.
92 Cummins Turbo Diesel
04 PT Cruiser
gtx6970
Quote from: Highbanked Hauler on March 02, 2020, 07:54:59 PM
yep,
I messed up you are correct
Montclaire
I watched a video on youtube with the old guy who used to be on HotRod TV.  He was installing a roof skin on a 70 Challenger.  They buzzed off a lot of the bad metal with an air shear which made it easier to separate the panels.  Be careful not to cut through the bracing and it would probably help to have a good spot weld cutter (Blair) and a flat panel chisel.  I think they also used a long air chisel.  Worth checking out.
