UNDERCOAT
Started by B54SPEED, March 03, 2020, 05:54:51 PM
B54SPEED
Did all Daytona's get full undercoat or would that have been an option  :shruggy:
Mopar John
The full undercoat was an option that included a under hood pad.
MJ
birdsandbees
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
B54SPEED
So would J55 be on the fender tag ?
birdsandbees
Broadcast sheet for sure. Not on a Lynch Rd tag for the '70 RR/Birds, but not sure how or if other plants put it on the fender tag for '69's.
No J55 on Daytona tags either.
held1823
i assume it would show in one of the blank boxes about midway across this row. did they fill in the description as well, or just the "55"
Ernie Helderbrand
XX29L9B409053
birdsandbees
From my Birds sheet..
B54SPEED
You guys are amazing !
THANKS!
Mopar John
Quote from: held1823 on March 04, 2020, 06:19:05 AM
The broadcast sheet in held1823's reply shows the undercoat/under hood pad option.
Look at row #8 then look in section J miscellaneous items box #55.
It has a #5 in that box so the car that sheet belongs to has the option!
MJ
held1823
Quote from: Mopar John on March 04, 2020, 12:49:26 PM
MJ
that is the sheet for 409053
Ernie Helderbrand
XX29L9B409053
taxspeaker
Here is build sheet from my Daytona #400569 on 1st picture (hard to see, but there) followed by build sheet on my green bird #174621 second, followed by  build sheet purple Hemi bird #161573 without undercoat, followed by grey bird #175686 with undercoat, same J55 code. Seems reasonable to say they only came undercoated when punched that way on build sheet.
J55, Line 8 of Daytona and Green Bird and Grey Bird
No entry Line 8 of Hemi Bird
B54SPEED
Thanks for the detailed pics.
johntpr
Just remember that the front fenders would not show signs of  undercoat even on an undercoat coded Daytona.  The front fenders are unique Daytona pieces that replaced the original fenders at  Creative.
graybo
My Superbird has factory undercoating but did not have the hood insulation nor the J55 code on the build sheet.   Whats up with that????? :popcrn:
birdsandbees
Quote from: graybo on March 06, 2020, 06:35:33 PM
Full undercoating or just the general wheel well areas and misc spot shots?? J55 is the full underside undercoated and the hood pad.
graybo
Quote from: birdsandbees on March 06, 2020, 06:41:13 PM
It was a full undercoat.  I am now trying to figure out if it was done at the dealer or buy the first owner?  Did Mopar undercoat the underside with the transmission and driveshaft in place? I had undercoating on my driveshaft, tranny, a arms, brake lines, etc.....
graybo
Quote from: graybo on March 06, 2020, 06:53:46 PM
I think I should do more research before I post.....Looking like my bird was Undercoated at or after the dealer.  I just looked at the shotty undercoat job that was sprayed everywhere and thought that it looked like a monday morning Mopar line job.
