My new patina'd RR1 burgundy 1968 Charger ("Ribeye")...mostly original paint
Started by 70B5Cuda, March 29, 2020, 09:36:25 AM
Rubberduck
Quote from: 6bblgt on March 29, 2020, 01:07:51 PM
"burgundy" is AWESOME  :drool5: based on the decklid, it's an early car - what are its other spec's?
How can you tell it´s an early car with a view on the decklid?
´68 Charger, 505 by CWE, 4-speed
70 sublime
Quote from: Rubberduck on February 04, 2021, 05:49:08 AM
Earlier deck lids had the webbing on the inside like the hood with the open spaces between the shapes and later ones were all one panel with no open holes between the shapes
70B5Cuda
1968 Roadrunner-6.1L, 6 speed, 3.91 Getrag, IRS
1968 Charger- 6.1L, TR-6060, 9"
1968 Charger in RR1 "Ribeye"
1969 Charger in EW1 "S'more"
1969 Charger Survivor-R6, 383, 727.....WRECKED
1970 Barracuda-6.1L, 6 speed, 4.10 S60
moparstuart
they are bonded together like hoods , the early ones you can see the glue on the inside of the lids
70B5Cuda
70B5Cuda
Rear filler panel support and rear filler panel are now installed. The rear filler panel fit better then anticipated. The flanges that are spot welded together needed pulled/clamped together but I am pleased with the fit overall. The first two pictures are of the real filler panel just resting in place. The rest are after its welded in place.
mopar4don
Quote from: 70B5Cuda on February 16, 2021, 10:05:57 AM
Did you trim the drivers side gutter lip?
Also what are your trunk lid gaps?
70B5Cuda
Nothing had to be trimmed on the gutters or filler panel. Since the quarters weren't messed with, the gaps are all the same as they were.
73rallye440magnum
Looks awesome.
Assuming two piece trunk pan is the only route if you aren't replacing quarters?
Current- 70 Charger XH29G Y3, F8, F8
Past- '73 Rallye U code, '69 Coronet 500 vert, '68 Roadrunner clone, XP29H8, XP29G8
INTMD8
I may have missed it, but are you going to try and duplicate the patina on that rear panel?
Maybe could have a photo scanned and vinyl wrap it
chargervert
Seeing the dutch panel fitting that well on a car with original rear quarter panels,makes me think the dutch panel probably isn't the issue with the panel coming up short,maybe the repro rear quarter panels are where the issue is.
70B5Cuda
Quote from: chargervert on February 17, 2021, 09:18:13 PM
I believe you are correct. Im guessing I just haven't learned that before because people usually just replace both quarters and dutch panel at the same time....compounding the errors
70B5Cuda
Cabin floor pan is in place. The insides of the subframe rails were treated with POR15.
Kern Dog
blakemon
70B5Cuda
The doors were pulled in order to rebuild the door hinges. Once the driver's door came off, I was a bit frustrated. My best guess is that the poor leading of the upper pillars allowed water to run down the pillars, which rusted out this area below the upper hinge. I called 521 Restorations and ordered up a driver's side post/pillar. It's so weird how such a solid car has rust in such odd places.
mopar4don
Quote from: 70B5Cuda on March 01, 2021, 08:46:13 PM
So it looks like you sectioned in the outer part of the pillar?
70B5Cuda
Yes, just sectioned it in, which will be easier to blend/hide later. It's like pulling a string on a sweater....it just keeps going. Here's the passenger side. It was also super disappointing to see the first time. But an original donor section was used and I think it turned out well.
70B5Cuda
Right rear valance corner was repaired and console brackets were installed.
70B5Cuda
Rear window corner patches and welding up the rear window staple holes...finally done with sheetmetal repair. Bodywork starts soon.
BrokenHero
Great thread!
Is there a wax/sealant you or your detailing buddy recommends after the buffing with the compound and wool pad? I'm getting some good results with a similar process and want to keep them.
Thanks!
1968 Dodge Charger
383 4 barrel
PP1 red, black vinyl top
Los Angeles, CA
70B5Cuda
Quote from: BrokenHero on March 13, 2021, 12:57:06 PM
Great thread!
Thanks!
There isn't a sealant on it.
BrokenHero
1968 Dodge Charger
383 4 barrel
Los Angeles, CA
