Steering shaft problem
Started by nitrousn, April 21, 2020, 05:32:53 PM
nitrousn
Having some issues and my steering shaft seems to be to short. It does not look to be collapsed. Does anyone have some inner shaft measurements. 69 Charger with power steering. Even some in car measurements like from lower bearing to shaft weld, gauge hole or coupler.
70 sublime
Did you ever have it hooked up before ?
Manual and power steering use different length shaft in the steering column
birdsandbees
Only takes clunking it on the floor to collapse the two piece shaft...
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
nitrousn
Quote from: 70 sublime on April 21, 2020, 09:47:29 PM
Yes it came out of the car. If it was manual I don't think the coupler would fit my power box.
nitrousn
Quote from: birdsandbees on April 21, 2020, 09:48:47 PM
I do not think that happened however something is obviously different. I was given some measurements to compare to what I have. Even though the shaft looks like it is not collapsed it is entirely possible is has.
nitrousn
Shaft was short. I took it apart 15 years ago and had everything neatly put away. I will never say never on the shaft being bumped, I just don't recall anything ever happening to it. Either way its fixed and in the car. Thanks for the help.
