Fi-Tech timing tweaks
Started by comet_666, May 04, 2020, 08:47:58 AM
comet_666
Had a nice day yesterday so I decided to tinker with a few things on the car, I have not driven it in about 6 months and when i did it ran a bit hotter with the fi tech. A few of you guys mentioned it was probably a timing issue as I have the fi tech controlling timing.
Here are a few screens I pulled yesterday if anyone has input. The car runs great, just hotter than I like.
Thanks!
comet_666
another one
comet_666
and another...this is AFR but I think it looks ok.
cdr
Ist chart
1. 18.8
2.23
3.42
4.32
5.20
6.33
7.36
comet_666
Thank you again CDR!
I was wondering about that, especially when I saw 5. It stumbles a bit at a light when I give it normal throttle, not sure if that is a timing thing or not.
cdr
Quote from: comet_666 on May 04, 2020, 08:07:36 PM
Be sure & listen for ping, Rattle
comet_666
Will do, if I do should I note what rpm range and dial that back?
cdr
Quote from: comet_666 on May 05, 2020, 08:07:02 AM
:2thumbs: also make sure the timing matches using a timing light
comet_666
I know base is 18, checked that last year with timing light.
XH29N0G
Please keep us posted on the progress and any changes.  I'll be interested to read this and am following.
Or maybe it protects us.
comet_666
Will do, as soon as it stops thinking it's early March and warms up i'll give it a go.
Hopefully it corrects the running hot issue and the initial stumble.
cdr
for those doubting 40ish light cruise timing
comet_666
What gears are you running?
I turn about 3000 at 70mph and my timing never went above 30ish lol
I can't wait to make that change and see what it does.
cdr
Quote from: comet_666 on May 06, 2020, 01:56:16 PM
3.54 gear, A518 OD trans with lock up converter
comet_666
I made the changes, seems to run about the same which is good, maybe a bit better throttle response off the start, now as far as temp goes, i think it got to 180 and that was after long drive and then sitting in driveway, for the most part it was running in high 170's..now it was only 60 outside. I think i pretty much cruised around at 2k RPM for the most part.
I did record the 2nd half of my initial run and did not notice any thing different really.
INTMD8
Quote from: cdr on May 05, 2020, 10:46:10 AM
Yes, this is a good point, and not only idle. At higher rpm as well.
