Strange starter issue.
Started by Kern Dog, June 20, 2020, 01:35:48 AM
krops cars
You may have voltage, but not the right amperage. Unhook coil wire. Go to starter. Check voltage during cranking. Or I don't know if this would work. If you have a quality set of jumper cables. When it cranks hard take your cable hook from battery to solenoid and see if that makes a difference.
1/0 is more then enough. I dont even have that large in the 63 to save weight and that is 13.5:1 compression and it spins over nice and fast with a single red top in the trunk.
krops cars
Good point. I 'm saying make sure it is heavy enough. I see that a lot in trunk mounts and also not grounded good enough.
Kern Dog
The new battery solved the problem instantly.
Before, the running voltage with the car idling was in the upper 14 volt range as if the battery was in need of a HUGE amount of juice to recharge. Now it idles in the high 13s.
It cranks over great in any condition.
The new starter didn't make a difference. Bypassing the solenoid didn't either. The battery made the difference. I hesitated to blame it since it was so new.
XH29N0G
It sucks when something new is the culprit because it shouldn't be that way.  Glad you sorted it out.
Or maybe it protects us.
Kern Dog
 :2thumbs:   Thank you. I feel the same way.
It can't be the battery...I bought it a few months ago!
green69rt
Quote from: Kern Dog on July 20, 2020, 04:49:33 PM
:2thumbs:
