Started by 40Windsor, August 21, 2020, 11:31:28 PM
40Windsor
Setting up my 742. New 3.23 gears, new bearings and shims, new Sure-Grip.
Pinion depth shims equal to .093, backlash of .007", preload at 13inLb with new setup bearing and NO seal.
I couldn't load it while turning, but got a bit of a pattern. What do y'all think?
cdr
40Windsor
Hmm both pictures show up for me.
Mopar Nut
 :shruggy: Can't see any pictures either.
40Windsor
Weird.
cdr
The best I can tell from the picture looks good
40Windsor
I'm trying to get an old phone to work. The camera on this one does not allow me to focus up close.
cdr
Quote from: 40Windsor on August 22, 2020, 09:29:37 AM
The objective is to get a centered football shaped pattern
40Windsor
Hopefully these are a little more clear.
cdr
40Windsor
Thanks. Got it all assembled with the new (non-setup) bearings and new seal. Final preload is 19inlb. Got it painted and installed in the freshly powder coated housing.
40Windsor
Maybe someone can help, as my local napa wasn't able to. Yoke on the 742 takes ubolts instead of strap to hold ujoints. Guy at napa says I'm wrong and it doesn't exist. Kept saying all Mopar vehicles use the 318-10 strap kit and none use u bolts.
Pinion has centering tabs with a space of 3.615" between them. Gap for the caps measures 1.055".
Tried Moog 457 ujoint, this fits the DS and yoke width but the caps can't seat and setting the strap on it leaves about 1/4" gap.
As I explained to the guy at napa, the pinion is clearly meant for u bolts as the holes are non threaded for 5/16 bolt to pass through and the back is machined for washers/nuts.
My question is, should I keep hunting for a bastard ujoint setup, or just get a new 7290 (or other size) yoke and have a new DS made to fit a non-conversion ujoint? I would be fine running a conversion ujoint for a while if I can find caps and ubolts that work. My current DS is 1" short from where I'd like it but still perfectly fine for what I need (moving up/down driveway from carport to garage).
cdr
Look them up for a ford 9in
40Windsor
Thanks. Will do in the morning. Any chance you know a PN?
As for napa u bolts, I tried SKF UJ329-10, but the C-C is too narrow. I'll check if UJ330-10 is different on the C-C.
40Windsor
Done with NAPA. Guy basically called me an idiot saying that I was wrong and all Dodges used straps and what I said I needed didn't exist. Went to a small auto parts/gun/Uhaul shop, told them what I had. He grabbed a Spicer 3-94-54X and said this is it. Slight tap with a hammer to get it through the paint and I now have a mounted DS.
I noticed U Joint repair stuff in the "HELP" section of Advance Auto. Perhaps check a few places around you.  :scratchchin:
Quote from: 40Windsor on October 11, 2020, 12:49:49 PM
The Detroit 7260 and 7290 yoke uses the straps and they aren't the same, each uses a different strap. The Spicer 1330 yoke uses u-bolts.
40Windsor
Quote from: John_Kunkel on October 16, 2020, 02:22:25 PM
Thanks. Got it figured out.
Just waiting on brake hoses for disc brake conversion to arrive and she will be drivable.
