Car keeps shutting off
Started by JMF, September 19, 2020, 02:38:45 PM
JMF
Sorry it's not on a Charger but on my 70 Satellite
I have a problem where the car keeps shutting off , it will only happen once or twice on a run out and it usually happens when idling , eg at the traffic lights or traffic jam
Initially I thought it only does it when slightly cold but today it did it at full operating temperature
It doesn't splutter and shut off like a fuel problem , it shuts off just like if you were to turn the ignition off
The car usually will start up right away again ok
Any ideas ? Many thanks
70 sublime
Next time try to wiggle the key as it is about to die
Might be worn in the ignition lock itself
XH29N0G
I had something like this and it was related to a connection in the switch.  I swapped in another switch and it helped.  Then I realized it was one of the connectors that was shaking and losing connection.  It was not the one at the firewall, but the one under the dash.  It would run and then shut off and then many times if I was driving on the highway in gear (transmission is manual) restart and continue to run.  This might not be it, but it might be worth checking.
Or maybe it protects us.
chargered
I had some issues similar to that a few years ago and found out it was a bad ground.  I think my orange box wasn't grounded very well.  Once I fixed the ground and added an extra one to be safe, I didn't have any more issues.
Check the long white connector that comes from the ignition switch to the dash harness. Is the big red wire getting toasty?  :scratchchin:
