Super Bird brake proportion and distribution block?
Started by 70gtx440dana, September 27, 2020, 03:27:17 PM
70gtx440dana
Looking for photos of the correct 70 Super Bird brake proportioning valve and distribution block photos. Trying to help a friend determine if his set up is correct. I think he may have a 69 style style set up that is causing issues with the 4 speed reverse lock out rod not fitting properly. I am pretty sure his is the same setup as in the photo below. Thanks in advance for any photos or assistance.  Joe
70 Road Runner FJ5 383-4speed Air Grabber
70 GTX FE5 440-4speed Dana 3.54
70 Charger R/T FJ5 440-4peed Dana 3.54
taxspeaker
That looks just like the setup on my AUTOMATIC Bird! DOn't have the 4-speed on a lift so can't say until next weekend and Im sure someone will get you an answer by then.
chaaargerb
here are a few on my bird
chaaargerb
couple more
chaaargerb
70gtx440dana
Great photos....thanks for the assistance. I will reply back with our findings.
Mopar Nut
chaaargerb
They plug that outlet because the secondary valve feeds both front brake lines.
birdsandbees
Yes the metering valve builds pressure allowing the rears to start working before the fronts come in on the single piston Kelsey/Hayes calipers. Makes for some fun bleeding...
1970 'Bird RM23UOA170163
1969 'Bee WM21H9A230241
1964 Dodge 440 62422504487
RSI700VIPER
Here's my set up.  Car is a 4-speed.
69 V2 Daytona 440 4-Speed 3.54 Dana
70 FJ5 Superbird 440+6 4-Speed 3.54 Dana
69 Talladega Torino 428 CJ
69 Mercury Cyclone Spoiler II Gurney Special
70 T6 Challenger T/A 4-speed
70 V2 Challenger R/T 440 Six Pack 4-speed
71 FC7 Challenger Vert Flemington Speedway Pace Car
71 V2 Challenger RT Formal Roof w/ V2 Stripe & Houndstooth
Dragon Slayer
There is no 69 set up that looks like the 70.  There is an early 70 3 piece and later 2 piece, but I would not know what is specifically correct for the SB.  Distribution block to metering valve for the front KH disc.  Then proportioning valve to rear drums on frame rail.  Later in 70 they combined the meter valve on the distribution with a rivet bracket, vice separate bolt on bracket.
69 was bendix disc with no metering valve.  So you just had distribution block and proportioning valve.
