Fuel filter lines
Started by frank1966, December 23, 2020, 08:15:22 PM
frank1966
Hello,
So I noticed that I have a 5/16 rubber hose squeezed onto the 3/8 nipple on my edelbrock carb. I have 5/16 lines all around. What are my options?
1. Leave it as is?
2. Get a 3/8 hose with filter and and 3/8 to 5/16 in line adaptor?
I cannot find an adaptor coming off the carb - I would need a 5/8 20 with a 5/16 nipple for the hose, I only see 5/8 with a 3/8 nipple.
My hose goes directly to the fuel pump from the carb - no hard lines
frank1966
I found on classic industries a fuel filter/vapor separator? My car did not come with this - 440. Is this necessary? I would need to also run a line back to the tank right.
You will need the bigger fuel tank pick up/sender, new line to pump, bigger line clips, correct pump and pump to carb. lines. Use existing fuel line as return for vapor separator.  :scratchchin: That's a lot of crap...is it running okay?
frank1966
yes running fine, just curious if its at all necessary
If it's not broke do not fix it. (How I hung on to my 70 for 25 years.)
Mebsuta
Quote from: frank1966 on December 23, 2020, 08:15:22 PM
Hello,
1. Leave it as is?
Mine RR is the same and been like that since about 1994.  I have looked around a little bit for a 5/16 fitting for that carb and never found one I liked, so I left it alone.
